Topic: sparkfun Accelerometer Breakout BMA180 aiuto con codice (Read 879 times) previous topic - next topic
ferdinando
//INTERRUPT DELL'ACCELEROMETRO ---------------
//  INT               |     Pin Digitale 2 per l'interrupt 0 (19 - Interrupt 2)
//SPECIFICI COMUNICAZIONE I2C-----------------
// SDI                |     SDA (pin analogico 4)
// SCK                |     SCL (pin analogico 5)
// SDO                |     GROUND
// CS                 |     VDD = 3.3V
mi danno un codice di esempio, il problema è che è in c, ma siccome sono un novizio, non so portarlo in pde.
Ovvero no so mettere il setup() e il loop().
MI date una mano??
questo è il codice:
Code: [Select]
Created on: Feb 8, 2010
Under project: BMA180
By: Jim Lindblom & Viliam Klein
Test code for the BMA180 - This code will verify SPI communication.
It will also verify that the INT pin is correctly connected.
INT test currenty uses the new_data_int functionality.
After testing INT pin, we will output the acceleration values.
#include <avr/io.h>
#include <stdio.h>
#include "bma180.h"
#define sbi(var, mask)   ((var) |= (uint8_t)(1 << mask))
#define cbi(var, mask)   ((var) &= (uint8_t)~(1 << mask))
//Arduino Pro Specific Defines
#define LED 5
//BMA180 Defines
#define CS 0 //pin for chip select
#define INT 1 // pin for interrupt
void ioinit(void);
void delay_ms(uint16_t x);
void delay_us(uint16_t x);
static int uart_putchar(char c, FILE *stream);
uint8_t uart_getchar(void);
static FILE mystdout = FDEV_SETUP_STREAM(uart_putchar, NULL, _FDEV_SETUP_WRITE);
void init_SPI(void);
void txdata(char data);
char rxdata(void);
char read(uint8_t address);
void write(uint8_t address, char data);
int init_BMA180(uint8_t range, uint8_t bw);
int check_interrupt(void);
int test_interrupt(void);
//Global Variables
int main(void)
char temp;
signed short temp2;
char inkey;
ioinit();
init_SPI();
sbi(PORTB,CS);
printf("\f");
printf("\n***************BMA180 Test****************\n\n");
// Init BMA at +/-2g and 10Hz, return error if not connected
while (init_BMA180(0x01, 0x00) != 0)
printf("Error connecting to BMA180\n");
delay_ms(1000);
printf("Successfully connected to BMA180\n");
while (test_interrupt() != 0)
printf("Interrupt test failed...\n");
delay_ms(1000);
printf("Interrupt test passed\n");
printf("\nPress any button to begin accel raw output...\n");
inkey = uart_getchar();
printf("\nACCx \tACCy \tACCZ\n\n");
// main program loop
while(1){
temp = 0;
while (temp != 1)
temp = read(ACCXLSB) & 0x01;
temp = read(ACCXMSB);
temp2 = temp << 8;
temp2 |= read(ACCXLSB);
temp2 = temp2 >> 2; // Get rid of two non-value bits in LSB
printf("%d \t", temp2);
while (temp != 1)
temp = read(ACCYLSB) & 0x01;
temp = read(ACCYMSB);
temp2 = temp << 8;
temp2 |= read(ACCYLSB);
temp2 = temp2 >> 2;
while (temp != 1)
temp = read(ACCZLSB) & 0x01;
temp = read(ACCZMSB);
temp2 = temp << 8;
temp2 |= read(ACCZLSB);
temp2 = temp2 >> 2;
printf("%d\n", temp2);
// init_BMA180
// Input: range is a 3-bit value between 0x00 and 0x06 will set the range as described in the BMA180 datasheet (pg. 27)
// bw is a 4-bit value between 0x00 and 0x09.  Again described on pg. 27
// Output: -1 on error, 0 on success
char temp, temp1;
// if connected correctly, ID register should be 3
if(read(ID) != 3)
return -1;
// Set ee_w bit
temp = read(CTRLREG0);
temp |= 0x10;
write(CTRLREG0, temp); // Have to set ee_w to write any other registers
// Set BW
temp = read(BWTCS);
temp1 = bw;
temp1 = temp1<<4;
temp &= (~BWMASK);
temp |= temp1;
write(BWTCS, temp); // Keep tcs<3:0> in BWTCS, but write new BW
// Set Range
temp = read(OLSB1);
temp1 = range;
temp1 = (temp1<<RANGESHIFT);
temp &= (~RANGEMASK);
temp |= temp1;
write(OLSB1, temp); //Write new range data, keep other bits the same
return 0;
// int check_interrupt()
// returns: 0 or 1 depending on status of PB1
if((PINB & (1<<1)) == 0)
return 0;
return 1;
// Check interrupt functionality on PB1
// Output: 0 on success, -1 on error
while(check_interrupt() != 0)
write(CTRLREG3, 0x12); // set new_data_int
delay_ms(100);
while(check_interrupt() != 1)
// write reset_int control bit to 1
write(CTRLREG3, 0x10);
write(CTRLREG0, 0x50);
return 0;
//write any data byte to any single address
//adds a 0 to the MSB of the address byte (WRITE mode)
address &= 0x7F;
//printf("\nWriting 0x%x to 0x%x\n", data, address);
cbi(PORTB,CS);
delay_ms(1);
txdata(address);
delay_ms(1);
txdata(data);
delay_ms(1);
sbi(PORTB,CS);
//returns the contents of any 1 byte register from any address
//sets the MSB for every address byte (READ mode)
char byte;
address |= 0x80;
cbi(PORTB,CS);
txdata(address);
byte = rxdata();
sbi(PORTB,CS);
return byte;
char rxdata(void)
//while((SPSR&0x80) == 0x80);
SPDR = 0x55;
while((SPSR&0x80) == 0x00);
return SPDR;
SPDR = data;
void init_SPI(void)
sbi(SPCR,MSTR); //make SPI master
sbi(SPCR,CPOL); sbi(SPCR,CPHA); //SCL idle high, sample data on rising edge
cbi(SPCR,SPR1);cbi(SPCR,SPR0);cbi(SPSR,SPI2X); //Fosc/4 is SPI frequency
sbi(SPCR,SPE); //enable SPI
    if (c == '\n') uart_putchar('\r', stream);
    loop_until_bit_is_set(UCSR0A, UDRE0);
    UDR0 = c;
    return 0;
    while( !(UCSR0A & (1<<RXC0)) );
    return(UDR0);
void ioinit (void)
int MYUBRR = 103; // Results in 9600bps@8MHz or 19200bps@16MHz
    //1 = output, 0 = input
    //DDRA = 0b00000000; //ADC inputs
    DDRB = 0b11101101; //MISO input, PB1 input
    DDRC = 0b11111111; //All outputs
    DDRD = 0b11111110; //PORTD (RX on PD0)
stdout = &mystdout; //Required for printf init
UBRR0H = (MYUBRR) >> 8;
UBRR0L = MYUBRR;
UCSR0B = (1<<RXEN0)|(1<<TXEN0);
UCSR0C = (3<<UCSZ00);
UCSR0A = (1<<U2X0);
TCCR2B = (1<<CS21);
//General short delays
    for (; x > 0 ; x--)
        delay_us(1000);
    while(x > 256)
        TIFR2 = (1<<TOV2); //Clear any interrupt flags on Timer2
        TCNT2 = 0; //256 - 125 = 131 : Preload timer 2 for x clicks. Should be 1us per click
        while( (TIFR2 & (1<<TOV2)) == 0);
        x -= 256;
    TCNT2= 256 - x; //256 - 125 = 131 : Preload timer 2 for x clicks. Should be 1us per click
Se per caso ci avete già lavorato con questo attrezzo per caso avete delle dritte???
avete codice funzionante da postare??
grazie a tutti.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
