Topic: Sound sensor arduino!! (Read 1 time) previous topic - next topic
vishalapr
Could someone tell me how to connect the sound sensor to the arduino and give me a test code  to test if the sound sensor is working.
like
If I clap or make a noise, then an LED goes on.
Thanks
Link to where I purchased my sound sensor
http://cgi.ebay.com/Sound-Sensor-Module-Arduino-Sensor-Shield-MCU-PIC-/120664016254?pt=LH_DefaultDomain_0&hash=item1c1822c57e
but I do not have a sensor shield... so....
Please tell me how to use a sound sensor without using a sensor shield.
Thanks
johnwasser
Find the schematic for the "sensor shield".  You will probably find that the three pins that connect to the 'sensor' are Power, Ground and AnalogIn.  I hope the device will work on 5 Volts.  Hook the "+DC12V" pin to +5V on the Arduino.  Hook the "GND" pin to Gnd on the Arduino.  Hook the "AUDIO" pin to the analog input of your choice on the Arduino (the example code uses Analog Input 2).
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
