Topic: Serial port ARDUINO NANO (Read 3067 times) previous topic - next topic
nas2b
Hi all !
Firstly excuse me for my bad english..
I have a little problem, i programmed my arduinio nano v3 with mini USB and my program work normaly but only when i use the USB connection ( integrated in the arduino, i have just to put my USB wire ). :)
My application is a compass who are connected at the arduino with i²c bus, and arduino give me 3 values like : "33 -66 34"; with usb connection i have no problem but with RS232 connection ( Tx, Rx and ground ) the response are like : x97\x00\xab\x2e\xac\x66\xga\xab....... =( ; And with RS232 connection i can't update my arduino
Tha data rate are corectly configured, flow control also.. :smiley-roll-sweat:
Do you know what is the problem ? :smiley-roll:
CrossRoads
If you are trying to connect RS232 to the RX/TX lines, you need to invert them.
RS232 use a High level to indicate nothing is going on, then a Low indicates a Start Bit has occured and data is starting.
The Aruino Rx/Tx lines use a Low level when nothing is going on, and Start Bit goes high.
So you need to invert the levels.
nas2b
Thank you for your reply.
But RS232 have just 1 protocol ? no ? i knew a problem could be the high logic level TTL or 3.3v but arduino give a high level TTL and it's the first time i hear this problem...
So i will try it, do you know any components who can do it ?
thanks a lot !
retrolefty
Quote
I believe you have that backwards. TTL serial uses true logic, a data bit is true high and a stop bit is equal to a data bit high and a start bit is equal to a data bit low, so the idle condition ("nothing going on") on a serial link is at a continous high (stop condition) waiting for the next start bit low.
Lefty
CrossRoads
Lefty,
I'm gonna have to pull out myscope & check again.
Maybe the device I was talking to was putting out TTL serial (low = nothing happening) and I had to invert coming in to see good data. I had worked that out last August.
Robert
retrolefty
Lefty,
Robert
Yes, one can once and awhile come across something using non-standard inverted logic. But standard TTL is as I stated. Simple test with just a voltmeter on the txd pin after loading this simple sketch. You will see the output is almost always +5vdc on both the send and receive arduino pins, as it's only sending one character every two seconds.
Code: [Select]
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
  // initialize the digital pin as an output.
  // Pin 13 has an LED connected on most Arduino boards:
  pinMode(13, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED on
  delay(1000);  // wait for a second
  Serial.println("?");
  digitalWrite(13, LOW);    // set the LED off
Lefty
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
