Loading...
Pages: 1 [2]   Go Down
Author Topic: Jerky servo!!!  (Read 1108 times)
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
To the servo - where else?
Don't forget to common the grounds.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Sr. Member
View Profile
When i give commands to the servo and/or the LED it works fine, but when I give commands to the motors it jitters and jerks, and the motors also go on only for half of a second or 1 and a half of a second sometimes when they are supposed to go on for 1 second.
How do I stop this happening
When I remove the servo then everything works fine but when I add the servo the above problem occurs...
Please help...
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
9V batteries are rubbish for powering high current devices like motors and servos.
Don't power anything other than LEDs off the Arduino.
Logged
Offline Offline
Sr. Member
View Profile
But if I add 4 AA batteries then the robot will become too heavy and will not be able to move...So is there no other alternative.
Logged
United States (Texas)
Offline Offline
God Member
Arduino socks
View Profile
maybe you should redesign your robot then? you could look for a flat lithium battery pack, it would be lighter and smaller, but you would need extra circuitry to charge it and prevent it from being discharged too much.
Logged
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
Quote
Looks like you have designed a robot that will not work. You really need to use google and other resources to look at how robots like the one you want have been built by others. Some robot kit sellers like lynxmotion (bottom) have assembly instructions for their products that can show you how things are done. Below is another resource that might be helpful. sorry your bot did not work for you, but maybe you can change it so it will work.
http://www.seattlerobotics.org/resources/RoboticsMiniFAQ.pdf
http://www.lynxmotion.com/driver.aspx?Topic=assem05
Logged
Why I like my 2005 rio yellow Honda S2000 with the top down, and more!
GOOGLE ADVANCED FORUM SEARCH BELOW!
Go to:  http://www.google.com/advanced_search?hl=en
put in key search words,
use site or domain:  http://arduino.cc/forum
or in a google search box put key words site:http://arduino.cc/forum
Offline Offline
Sr. Member
View Profile
All right I'll redesign my robot.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
