Loading...
Pages: 1 [2]   Go Down
Author Topic: Digital imput via arduino to processing  (Read 1618 times)
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quite so
Mein Luftkissenfahrzeug ist mit Aalen gefüllt
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Global Moderator
Melbourne, Australia
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
How about answering my questions in reply #14.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Sie haben schöne Oberschenkel.
Logged
Global Moderator
Offline Offline
Shannon Member
Lua rocks!
View Profile
WWW
Sorry, was bad coment, now I changed. How now ?
So far I haven't seen a single line of code that you have posted with the [ code ] tags as we have repeatedly requested. You want people to help you but are not prepared to take a couple of minutes to work out how to do that.
Your comments do not agree with the code you post. That shows a lack of attention to detail. Detail is what makes programs work. The computer cannot read your mind, nor can we. Code like this (bearing in mind the comments) show a total confusion on your part:
Quote
Code:
int switchPin = 4;                       // Switch connected to pin 4
  pinMode(switchPin, INPUT);      // Set pin 0 as an input
Meanwhile comments like this, while correct:
Quote
Code:
  if (val == 2) {              // If the serial value is 2,
... simply do not add anything at all to the code.
Imagine if I said this:
Code:
if (a == 2)   // if a is 2
What has the comment done? Has it helped in any way?
Or this:
Code:
a = 42;   // make a have the value 42
Try to think clearly. Programming is not about writing "stuff that looks like programs". It is about understanding what you are doing.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
