Topic: Digital imput via arduino to processing (Read 8557 times) previous topic - next topic
Zenolin
Apr 30, 2011, 10:37 am Last Edit: Apr 30, 2011, 09:24 pm by Zenolin Reason: 1
Processing code:
import processing.serial.*;
Serial myPort;  // Create object from Serial class
int val;      // Data received from the serial port
 size(200, 200);
 // I know that the first port in the serial list on my mac
 // is always my  FTDI adaptor, so I open Serial.list()[0].
 // On Windows machines, this generally opens COM1.
 // Open whatever port is the one you're using.
 String portName = Serial.list()[0];
 myPort = new Serial(this, portName, 9600);
void draw()
 if ( myPort.available() > 0) {  // If data is available,
   val = myPort.read();         // read it and store it in val
 background(255);             // Set background to white
 if (val == 2) {              // If the serial value is 2,
   fill(0);                   // set fill to black
} else if (val == 1) {
   fill (204);
   fill (204, 102, 0);
} rect(50, 50, 100, 100);
Arduino code:
// Wiring / Arduino Code
// Code for sensing a switch status and writing the value to the serial port.
int switchPin = 4;     // Switch connected to pin 4
int ZZZZ = 7;   // Switch connected to pin 7
 pinMode(switchPin, INPUT);
pinMode(ZZZZ, INPUT);
 Serial.begin(9600);                    // Start serial communication at 9600 bps
 if (digitalRead(switchPin) == HIGH) {  // If switch is ON,
   Serial.print(1, BYTE);               // send 1 to Processing
 } else {                               // If the switch is not ON,
   Serial.print(0, BYTE);               // send 0 to Processing
if (digitalRead(ZZZZ) == HIGH) {  // If switch is ON,
   Serial.print(2, BYTE);               // send 2 to Processing
 delay(100);                            // Wait 100 milliseconds
Do not workink good. I did mistake in arduino code , but i do not now there. Please help.
AWOL
#1
Apr 30, 2011, 10:46 am Last Edit: Apr 30, 2011, 10:47 am by AWOL Reason: 1
http://arduino.cc/forum/index.php/topic,59849.15.html
int ZZZZ = 7;  // Switch connected to pin 4
pinMode(ZZZZ, INPUT);  // Set pin 0 as an input
Comments like that are simply noise. They should not be there.
AWOL
Now I changed coments
pinMode(switchPin, INPUT);  // Set pin 0 as an input
Ok, right.
3dprinter
It is always instructive to see the other posts made by a person asking... So, I gather you finally have gotten the Processing/Arduino distiction sorted out (earlier thread)
Lets see what you are doing. The Arduino code is sending two bytes roughly ten times a second. It can be sending 00, 10, 02 or 12 depending on the state of the switches.
The Processing colours a rectangle : IF "2" then white, if "1" then gray, else brown.
So.... if you only press one button on the Arduino then the other button's "0" signal will colour the rectangle ... (that is a hint)
Please please, when asking question make it clear which bit is not working. You may find - I have a few times - that explaining precisly what goes wrong, makes you find the error yourself (usually while writing the post, which then does not have to be sent  :) )
EACH time you ask include three things:
1: What did you do?That is the code, the circuit diagram, what commands, button pushes you do.
2: What did you want to happen? (f.ex: The LED blinks 5 times at left button push; the LED turns Green on temperature exceeding 20C)
3: What actually did happen? (f.ex: The LED blinked once; The RGB-LED turn Yellow instead of Green at 20C and turned Green at 30C)
BTW, there is a Processing forum, too.
3dprinter
AWOL
I am fed up. Please make me happy.
Two men meet in the street.
The first one says "How are you - I haven't seen you for ages"
"Oh, I'm OK, but my wife has left me. She said she was going out to buy a pint of milk and never came back", says the second.
"That's awful!", said the first, "How are you managing?"
"I'm just having to use the powdered stuff", says the second.
3dprinter
Zenolin, in reply to the message you sent me
plese help me.
Here not mistake, bet do not work good.
    delay(100);
//  delay(100);                            // Wait 100 milliseconds
Bad English is excusable, I can understand despite numerous spelling mistakes, wrong grammer and worse.
It is that you still have not said what it is that does not work. You expect me (or other Forum users), from the program and your cryptic "bet do not work good" to guess what you are expecting to happen, from what I can derive that the program actually does (and that is not always easy). In this case, is it showing the wrong colurs on your Processing or too briefly? Are your buttons something that is held down a long time or something that happens very quickly?
(1) What are you doing (2) What are wanting to happen (3) what is actually happening
I can't be bothered with so little info. Sorry.
nickgammon
blinkink screen with it :
  if ((digitalRead(switchPin) == LOW) || (digitalRead(switchPin3) == LOW)) {   // If switch is ON,
  } else if (digitalRead(switchPin) == HIGH) {
  } else if (digitalRead(switchPin3) == HIGH){   // If switch is ON,
You want help enough to make scrolling messages in all caps, right?
Well can you answer this ...
You have two switches, switchPin and switchPin3. Now can you explain under what circumstances you conceive that his line of code will be executed?
(the last one, not the first one)
Also can you explain when you think that it will execute this:
Let me give you a hint. Do a truth table. There are four possible combinations:
00
01
10
11
Now look at your code and see what path will be taken for each of those.
nickgammon
Also, if you want help that badly, how about learning how to post your code in "code" blocks like I did above? It is part of the forum, and makes your posts more readable, and thus more likely to be answered.
AWOL
#9
May 01, 2011, 11:23 am Last Edit: May 01, 2011, 11:26 am by AWOL Reason: 1
No, he meant using the # icon on the editor's toolbar to put the code in a proper code box.
Serial.print(00, BYTE);
Zero is zero whether you express it in octal or decimal.
nickgammon
 if (val == 10) {              // If the serial value is 2,
You lost me there.
bubulindo
You lost me there.
0b10 = 2 = 0x02. That's what I think he's trying.
This is the dark side of Arduino... people get empowered by the little device, but there are some things you can't do if you don't put an effort into it. (althgouh in this case it might be lack of information in whatever language Zenolin speaks).
This... is a hobby.
nickgammon
Oh, OK.
@Zenolin:
http://en.wikipedia.org/wiki/Number_base
Look, attention to detail is very, very important.
If I said to you go buy 10 apples, would you return with 2 of them?
AWOL
Well, to be fair, you didn't specify that the combinations were written in binary  ;-)
nickgammon
