Sorry, was bad coment, now I changed. How now ?
So far I haven't seen a single line of code that you have posted with the [ code ] tags as we have repeatedly requested. You want people to help you but are not prepared to take a couple of minutes to work out how to do that.
Your comments do not agree with the code you post. That shows a lack of attention to detail. Detail is what makes programs work. The computer cannot read your mind, nor can we. Code like this (bearing in mind the comments) show a total confusion on your part:
int switchPin = 4; // Switch connected to pin 4
pinMode(switchPin, INPUT); // Set pin 0 as an input
Meanwhile comments like this, while correct:
if (val == 2) { // If the serial value is 2,
... simply do not add anything at all to the code.
Imagine if I said this:
if (a == 2) // if a is 2
What has the comment done? Has it helped in any way?
Or this:
a = 42; // make a have the value 42
Try to think clearly. Programming is not about writing "stuff that looks like programs". It is about understanding what you are doing.
