Topic: Ardumoto - Motor Driver Shield (Read 1 time) previous topic - next topic
13pboys
hi there im trying to make two, two way motors work with a thumb stick.
and all i have is this and i cant seem to get is to work
int pin1 = 0;
int pin2 = 0;
int pwm_a = 3;  //PWM control for motor outputs 1 and 2 is on digital pin 3
int pwm_b = 11;  //PWM control for motor outputs 3 and 4 is on digital pin 11
int dir_a = 12;  //direction control for motor outputs 1 and 2 is on digital pin 12
int dir_b = 13;  //direction control for motor outputs 3 and 4 is on digital pin 13
  pinMode(pwm_a, OUTPUT);  //Set control pins to be outputs
  pinMode(pwm_b, OUTPUT);
  pinMode(dir_a, OUTPUT);
  pinMode(dir_b, OUTPUT);
  analogWrite(pwm_a, 100);  //set both motors to run at (100/255 = 39)% duty cycle (slow)
  analogWrite(pwm_b, 100);
  digitalWrite(dir_a, LOW);  //Set motor direction, 1 low, 2 high
  digitalWrite(dir_b, LOW);  //Set motor direction, 3 high, 4 low
  analogWrite(pwm_a, 255);  //set both motors to run at 100% duty cycle (fast)
  analogWrite(pwm_b, 255);
  digitalWrite(dir_a, HIGH);  //Reverse motor direction, 1 high, 2 low
  digitalWrite(dir_b, HIGH);  //Reverse motor direction, 3 low, 4 high
3dprinter
" i cant seem to get is to work" does not say what does not work. Do the motors not turn at all? Or do they turn to fast/wrong way or what?
Your subject mentions "Motor shield". How have you verified that the wiring is correct? - perhaps including a schematic here might help resolve the problem.
