Connecticut
Offline
Edison Member
RTFD (Datasheet in our case)
« on: April 30, 2011, 04:16:35 pm » |
I am interested in getting some wireless networks working for remotely controlling a robot w/ arduino from another arduino. Before you say Xbees, I have a mac and therefore can't config them.
I'm not really interested in extreme speed, but I want something that is cheap and easy to use. Any suggestions?
Logged
I'm not kidding. If I am asking a question whose answer is found within the concerned product's datasheet, shame on me. If I am answering a similar question, shame on you!
Offline
Jr. Member
« Reply #1 on: April 30, 2011, 04:56:20 pm » |
Well, the vast majority of xBee configuration can be done with just a terminal program, so you can do almost everything you'd need on a Mac. Only thing you need a PC for is to install the firmware onto the xBee in the 1st place, so if you can occasionally borrow a friend's PC, you should be ok. That being said, here's a good summary of what's out there: http://www.sparkfun.com/tutorials/128
Logged
Connecticut
Offline
Edison Member
« Reply #2 on: April 30, 2011, 05:24:03 pm » |
But Xbees will be overkill. Some of them have a freakin' 1 MILE range! I'm talking about ~20ft maximum. Do the General TX/RX (from sparkfun, cheap) work well if I use the virtual wire library?
Thanks!
Logged
0
Offline
Jr. Member
Arduino rocks
« Reply #3 on: May 01, 2011, 04:53:26 am » |
Logged
Sussex UK / CT USA
Offline
Edison Member
Forums forever
« Reply #4 on: May 01, 2011, 06:49:39 am » |
Do the General TX/RX (from sparkfun, cheap) If you mean the ones I think you mean, I don't think they can do what I think you think they can.
Logged
Connecticut
Offline
Edison Member
« Reply #5 on: May 01, 2011, 07:40:29 am » |
This is the general TX/ RXThe JeeNode uses this. Has anyone used it? Is it easy to use/reliable? It is smd, but the pin spacing is 2mm. Thanks!
Logged
Lancashire, UK
Offline
Edison Member
« Reply #7 on: May 01, 2011, 09:20:59 am » |
The simple TXRX pairs work in line with what you pay for them, the virtualwire library is a software fudge to get around some of the issues with such primitive radio gear (in theory it should work with plain old serial). Theres no error detection/correction as there there is with the bluetooth/wifi based kit, you write it yourself and live with the limitations.
Logged
Connecticut
Offline
Edison Member
« Reply #8 on: May 01, 2011, 09:28:37 am » |
But all I want to do is to send two integers- joystick y axis and joystick x axis. I should be able to send this with good enough speed and reliability as there is no noticeable errors or lag, right?
Logged
Lancashire, UK
Offline
Edison Member
« Reply #9 on: May 01, 2011, 10:01:12 am » |
I ran mine at 1000 bits / second to get the errors down. It worked but it wasn't fast. I used a checksum system for error detecting and ignored the stuff that didn't pass the checksum. Its one way only, so you need a pair to get a back channel. I would have doubts about running a TX and RX together on similar frequencies in close proximity. Its crude ASK modulation which is just on/off keying, the limitations of the simple AGC on the receiver is what the virtualwire library is supposed to help out with. http://en.wikipedia.org/wiki/Amplitude-shift_keying If one way and two values will do, its probably worth a stab for the low cost. You're probably limited to checksums as error detection and there is no back channel to request a resend. Just don't expect too much
Logged
Connecticut
Offline
Edison Member
« Reply #10 on: May 01, 2011, 10:37:58 am » |
What about the Hope RFM12 or 22 modules? are those any good? There only $2 or $3 more expensive.
And I don't need 2-way: just sending 8 bit integers in 1 direction.
Logged
Lancashire, UK
Offline
Edison Member
« Reply #11 on: May 01, 2011, 11:30:58 am » |
No direct experience with them, but FSK has to be an improvement on ASK. Its still just on/off keying though.
Logged
Connecticut
Offline
Edison Member
« Reply #12 on: May 01, 2011, 01:43:08 pm » |
What would you do for single direction, cheap RF?
Logged
Lancashire, UK
Offline
Edison Member
« Reply #13 on: May 02, 2011, 08:35:12 am » |
I used mine to avoid the need to run wires on a fixed installation, I abandoned wireless and just ran a cable in the end. I suspect the Hope kit using FSK would work better than the cheap ASK type, due to the AGC situation with FM modulation rather than AM, I reckon using the virtualwire library wouldn't give you any advantages over straight serial. I'd certainly look at it. FM/FSK is much less prone to interference than AM/ASK.
Logged
Connecticut
Offline
Edison Member
« Reply #14 on: May 04, 2011, 02:11:50 pm » |
Or how about a nordic module such as this one? They are as expensive as xbee's, but you need minimal supporting hardware.
Logged
