Topic: Help with project for school (Read 950 times) previous topic - next topic
masonping
Hello,
Recently purchased a Inventors Kit for a school project and was hoping to get a servo to respond to a mouse moving up and down the x axis without going beyond the 180 range of the toy servo. I was able to run the servo from the beginners guide and also was able to get it to work based off of a mouses on screen movements. Unfortunately the screen is not going to be visible during use so I need it to not be limited to a area I cant blindly stay in. Any suggestions for other tutorials or project s floating around would be fantastic.
Thank you for your time.
masonping
to clarify the second project with the mouse controlled servo was one I found online. My coding skill is not impressive
AWOL
It would be useful to see your work so far, but in its absence:
http://arduino.cc/en/Reference/Constrain
http://arduino.cc/en/Reference/Map
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
masonping
// Use the included processing code serial library
import processing.serial.*;
int gx = 15;
int gy = 35;
int spos=90;
float leftColor = 0.0;
float rightColor = 0.0;
Serial port;                         // The serial port
  size(720, 720);
  colorMode(RGB, 1.0);
  noStroke();
  rectMode(CENTER);
  frameRate(100);
  println(Serial.list()); // List COM-ports
  //select second com-port from the list
  port = new Serial(this, Serial.list()[1], 19200);
void draw()
  background(0.0);
  update(mouseX);
  fill(mouseX/4);
  rect(150, 320, gx*2, gx*2);
  fill(180 - (mouseX/4));
  rect(450, 320, gy*2, gy*2);
void update(int x)
  //Calculate servo postion from mouseX
  spos= x/4;
  //Output the servo position ( from 0 to 180)
  port.write("s"+spos);
  // Just some graphics
  leftColor = -0.002 * x/2 + 0.06;
  rightColor =  0.002 * x/2 + 0.06;
  gx = x/2;
  gy = 100-x/2;
masonping
This is the code I was using from the online tutorial. From your post's I've gather I should be assigning a set of high and low's somewhere. I can see were the grey note is explaining that section of the code but I don't see how it is controlling it
masonping
It works but it sounds like it is pushing the servo beyond its limit
masonping
int gx = 1;
int gy = 1;
int spos=90;
  size(1080, 1080);
  frameRate(100);
void draw()
  background(0.0);
  update(mouseY);
void update(int x)
  spos= x/6;
  gx = x;
  gy = x;
I was able to cut out things I learned I didn't need and switch it to the Y axis as I was hoping to do. I resized it to my screens resolution and changed the division so I am getting 180 degree. I just cant figure out how to add an exception to stop it when it gets to the top of the screen. The servo properly stops at the bottom but I need it to cut out when it reaches the top of the block also, other wise it will burn it out.
Here is the tutorial I am going from
http://arduino.cc/playground/Learning/SingleServoExample
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
