Loading...
Pages: [1]   Go Down
Author Topic: how can i create a program for a 6v motor  (Read 469 times)
Offline Offline
Newbie
View Profile
 i was making some programs for this but my motor doesn't work pleas help me!!!!
(i believe) this is the best program:
#include <IRremote.h>
int RECV_PIN = 9;
int motor1 =  7;
int motorpwm=  3;
int motor2 =  6;
IRrecv irrecv(RECV_PIN);
decode_results results;
 irrecv.enableIRIn(); // Start the ir receiver
 pinMode(motor1, OUTPUT);
 pinMode(motor2, OUTPUT);
 pinMode(motorpwm, OUTPUT);
 if (irrecv.decode(&results)) {
   Serial.println(results.value, DEC);
   if(results.value == 2800){  //if you want to configure with your remote controll change the results.value
     digitalWrite(motor1, HIGH);   // set the LED on
     digitalWrite(motor2, LOW);
  if(results.value == 2672)
     digitalWrite(motor1, LOW);   // set the LED off
   irrecv.resume(); // Receive the next value
   if(results.value == 752)
  analogWrite (motorpwm, 220);
Logged
San Diego, California
Offline Offline
Newbie
View Profile
WWW
Simplify your sketch and try one thing at a time.
First create a sketch that just runs the motor back and forth. Get that working before going to the next step
Then create another sketch that reports the IR status on the Serial Monitor window. Get that working.
Now you can combine the two.
Without getting into the sketch itself, your problem could be just about anything, so you need to take things one step at a time, and verify that the parts of your scheme work as expected. Maybe you're not using the right type of IR remote for the codes you're looking for. Who knows.
Logged
Pages: [1]   Go Up
Print
Jump to:
