Topic: Building a function generator (Read 4663 times) previous topic - next topic
bubulindo
if you have a mega board, parallel is the way to go! ;)
This... is a hobby.
baum
Not neccesarily. You only need 17 pins for the dac. (using the analog inputs as outs).
compuslave
I have uno and I also have an extra micro-controller for it, since I'm prone to cook such things.
Never judge a man until you walk a mile in his shoes. But, by that time you're a mile away and you got his shoes, so screw em'
baum
compuslave
bubulindo
Yes... if you want to use up all the pins in the arduino. That kinda makes it a bit limited. Say you wanted a function generator that could work without being connected to the computer.
My comment was also referring the possibility of using the external memory bus. With which you could put in a bit more RAM/FLASH/EEPROM and have even crazier waveforms going on, that is if you create them using tables.
I wouldn't go for that though... most of the functions on the function generator can be programmed as a proper time-based function, that would make it far more flexible with better results, although it would be a bit tricky to implement.
This... is a hobby.
baum
True. Then you may want a mega.
u0421793
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
