Topic: Sensor Data Help (Read 784 times) previous topic - next topic
twisternhra
I have an 3 wire Eaton iProx sensor that detects metal. Since it needs 6-48v to operate I am using a 9v battery to power it. Whenever it detects metal it outputs the input voltage through the signal wire. I am using a 7805 voltage regulator to bring it down to 5v so I can plug that into my Arduino. Would it be better to use a transistor instead since the Arduino and the sensor are both using different power sources? I have a schematic for it below I don't know if I drew it properly though.
RuggedCircuits
I think it would be easier to just use a resistor and zener diode combination, like this:
http://ruggedcircuits.com/html/circuit__27.html
Do not enable the pullup resistor though.
The Rugged Motor Driver: two H-bridges, more power than an L298, fully protected
twisternhra
Where could I get one of those from?
RuggedCircuits
This should work:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=1N5230B-TPCT-ND
Beat707: MIDI drum machine / sequencer / groove-box for Arduino
twisternhra
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
