« on: May 01, 2011, 03:23:14 am » |
title says it all, what are the differences? i am thinking there would be an issue burning a bootloader to the 328 since it is probably expecting the 328p, and is the 328 newer or older than the 328p? everything i have has a 328p in it but the 328 is $1 cheaper and that adds up quick in volume, so please let me know the difference.
bob
Dallas
Shannon Member
« Reply #1 on: May 01, 2011, 03:47:35 am » |
Looks like the P uses a bit less power and has a few more machine instructions.
« Reply #2 on: January 06, 2013, 07:16:04 pm » |
South Texas
« Reply #3 on: January 07, 2013, 12:34:43 pm » |
The 2 devices have a different signature. I added the 328 to my Arduino and AVRDude files so that makes it easier to burn a bootloader. Once the bootloader is loaded they are interchangeable in the Uno board so the Uno config is sufficient to program them. I have a couple 328's that I have installed the bootloader on. they have all been in my arduino board and also in a wireless breadboard that has a MAX232 for a serial interface. Once the bootloader is loaded they all function the same with the ArduinoIDE.
Functionally I think the only real difference is in low power operation.
Boston area, metrowest
« Reply #4 on: January 07, 2013, 01:40:40 pm » |
In addition to the power usage difference and the signature byte difference:
There's a Brownout difference:
BOD disable only available in picoPower devices ATmega48PA/88PA/168PA/328P BODS and BODSE only available for picoPower devices ATmega48PA/88PA/168PA/328P
There's a couple of instruction differences, see page 522: BRANCH INSTRUCTIONS Mnemonics Operands Description Operation Flags #Clocks JMP(1) k Direct Jump PC <-- k None 3 CALL(1) k Direct Subroutine Call PC <-- k None 4
Note: 1. These instructions are only available in ATmega168PA and ATmega328P.
the land of sun+snow
« Reply #5 on: January 11, 2013, 02:15:37 pm » |
Bob, on a slightly different tack, is there a difference, other than the chip-signature, between using a 1284 versus 1284P chip with the Bobuino or other 1284P bootloader?
Also, what does the pins.ods file in the Bobuino variant directory do?
« Reply #6 on: January 11, 2013, 02:37:38 pm » |
Dan, What you can is is browse the spec http://www.atmel.com/Images/doc8272.pdf(which I can't seem to download at the moment) and search/find all occurrences of 'atmega2184p' which will find all the instances of uniquenesses of atmega1284p vs all the samenesses between 1284/p. pico power, signature bytes, brownout detection might be 1 or 2 other things. I don't know what pins.ods does, need to open when I get home & see. maniacbug put all that together, the pins_arduino.h was modified for my board types, the other files are all likely the same. I think the 1284 boards all point to same bootloader - check the boards.txt to confirm. I can upload the one I am using, which flashes the SCK pin after the install. I think it is the same as what is on the github site.
« Reply #7 on: January 11, 2013, 02:47:50 pm » |
Finally downloaded, the May 2012 complete version. Page 62,63 - interrupt difference
For the charts that start at Section 28 & 29, you'd have to look at the two side by side to see the difference between non-Pico and Pico power.
Left Coast, CA (USA)
Measurement changes behavior
« Reply #8 on: January 11, 2013, 02:52:11 pm » |
Seems the P version has a timer3 that the non P doesn't, that's rather significant. Does manics port define and support timer 3?
« Reply #9 on: January 11, 2013, 02:57:11 pm » |
Dan, What you can is is browse the spec http://www.atmel.com/Images/doc8272.pdf(which I can't seem to download at the moment) and search/find all occurrences of 'atmega2184p' which will find all the instances of uniquenesses of atmega1284p vs all the samenesses between 1284/p. pico power, signature bytes, brownout detection might be 1 or 2 other things. I don't know what pins.ods does, need to open when I get home & see. maniacbug put all that together, the pins_arduino.h was modified for my board types, the other files are all likely the same. I think the 1284 boards all point to same bootloader - check the boards.txt to confirm. I can upload the one I am using, which flashes the SCK pin after the install. I think it is the same as what is on the github site. I opened a pins.ods file and it opened up into an open office spreadsheet, so perhaps it's just an aid/tool he uses to build his various custom pins_arduino.h file? Lefty
« Reply #10 on: January 11, 2013, 03:20:49 pm » |
Thanks, I looked at the 584 page d/s, and decided it was easier to ask the experts!
BTW, out of stupidity, I bought a couple of the atmega1284-PU chips instead of the atmega1284P-PU chips, and to burn the bootloader, I found I had to track down the avrdude.conf file and change to the chip-signature to that for the 1284. Then, it burned the bootloader ok using the ArduinoISP sketch from a UNO chip.
However, to download sketches into the 1284 bootloader chip using the IDE, I then had to change avrdude.conf back to the original 1284P chip-signature. Interesting.
Also, thanks for building the Bobuino bootloader. It's much more Arduino pin-compatible than the others.
« Last Edit: January 11, 2013, 03:25:07 pm by oric_dan(333) »
« Reply #11 on: January 11, 2013, 04:42:01 pm » |
You're welcome. However: I didn't build the bootloader, I just developed the pinout I wanted. maniacbug did the software. I had something mangled together for IDE -0023, but the change for 1.0 was more than I was able to figure out.
I think you can copy the 1284P section in avrdude.conf, call it mega1284. Then do the same in boards.txt, make a new section with new name and call out mega1284 vs mega1284p Should let you have 2 versions and not have to switch back & forth. Worth a shot anyway!
« Reply #12 on: January 11, 2013, 04:57:15 pm » |
Also, thanks for building the Bobuino bootloader. It's much more Arduino pin-compatible than the others. Again the bootloader used has nothing to do with the pin abstraction defined with the custom pins_arduino.h file used for a modified core. The bootloader used is reflected in the boards.txt entry of a specific board selection and tells the IDE the baudrate used for the bootloader as well as the memory size and the fuse and lock bit values used. The pins_arduino.h file is where one defines the abstracted arduino pin numbers to the physical port.pin numbers of the chip. Lefty
vermont
« Reply #13 on: January 11, 2013, 04:57:56 pm » |
that is an error in the datasheets. there is no difference in timers between the two chips.
« Reply #14 on: January 11, 2013, 05:03:43 pm » |
that is an error in the datasheets. there is no difference in timers between the two chips. I don't think so. I didn't even know there was a non-P version of the 1284 before today, but that latest datasheet showing a non-P chip version avalible is pretty consistent through out that the timer3 (of timer0 through timer3) in not applicable to the non-P chip. Even the front page summary has: Peripheral Features – Two 8-bit Timer/Counters with Separate Prescalers and Compare Modes – One/two 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode I take that to mean the 1284P has 2 8 bit timers and 2 16 bit times, where as the non-P has two 8 bit timers but only one 16 bit timer. You disagree, if so why? Edit: Interesting, if you look at the cover sheet page of a old data sheet it states: • Peripheral Features – Two 8-bit Timer/Counters with Separate Prescalers and Compare Modes – One 16-bit Timer/Counter with Separate Prescaler, Compare Mode, and Capture Mode So comparing the two datasheets ( 8272A–AVR–01/10 Vs 8272D–AVR–05/12 ) it would seem that the 1284P gained a fourth timer rather then the non-P losing a timer it never had. Pretty confusing all in all. Lefty
« Last Edit: January 11, 2013, 05:49:21 pm by retrolefty »
