Loading...
Pages: [1]   Go Down
Author Topic: Sparkfun RG LED 8x8 Matrix - Help Please!!  (Read 660 times)
Offline Offline
Newbie
View Profile
Good morning,
I've just bought an Arduino Uno and a sparkfun RG matrix: http://www.sparkfun.com/products/759
And i have read as many forum posts as possible but i just can't get the thing to work.
I'm pretty sure the wiring is correct (for uno): 10 to CS, 11 to MISO and 13 to SCLK (and power obviously)
When i power on i get the lines scroll across in green red and orange. Then i get nothing, no matter what i try.
I can see the led on pin 13 flashing away so i think stuff is moving over.
Could this be the firmware on the backpack? i see the RGB has updated firmware, but no one ever seems to answer anyone's questions about the RG one on sparkfun.
Just as a bit of background i attach a couple of sketches i've tried:
Quote
// Simple program to test using the Arduino with the RGB Matrix
// & Backpack from Sparkfun. Code is a combination of Heather Dewey-Hagborg,
// Arduino Forum user: Little-Scale, and // Daniel Hirschmann. Enjoy!
// The Backpack requires 125Khz SPI, which is the slowest rate
// at which the Arduino's hardware SPI bus can communicate at.
// We need to send SPI to the backpack in the following steps:
// 1) Activate ChipSelect;
// 2) Wait 500microseconds;
// 3) Transfer 64bytes @ 125KHz (1 byte for each RGB LED in the matrix);
// 4) De-activate ChipSelect;
// 5) Wait 500microseconds
// Repeat however often you like!
#define CHIPSELECT 10//ss
#define SPICLOCK  13//sck
#define DATAOUT 11//MOSI / DI
#define DATAIN 12//MISO / DO
int data[] =
{0,0,0,0,0,0,0,0,
0,0,1,1,0,1,1,0,
0,1,0,0,1,0,0,1,
0,1,0,0,0,0,0,1,
0,0,1,0,0,0,1,0,
0,0,0,1,0,1,0,0,
0,0,0,0,1,0,0,0,
0,0,0,0,0,0,0,0
char spi_transfer(volatile char data)
SPDR = data;                    // Start the transmission
while (!(SPSR & (1<<SPIF)))     // Wait the end of the transmission
byte clr;
pinMode(DATAOUT,OUTPUT);
pinMode(SPICLOCK,OUTPUT);
pinMode(CHIPSELECT,OUTPUT);
digitalWrite(CHIPSELECT,HIGH); //disable device
SPCR = B01010001;             //SPI Registers
SPSR = SPSR & B11111110;      //make sure the speed is 125KHz
SPCR bits:
 7: SPIEE - enables SPI interrupt when high
 6: SPE - enable SPI bus when high
 5: DORD - LSB first when high, MSB first when low
 4: MSTR - arduino is in master mode when high, slave when low
 3: CPOL - data clock idle when high if 1, idle when low if 0
 2: CPHA - data on falling edge of clock when high, rising edge when low
 1: SPR1 - set speed of SPI bus
 0: SPR0 - set speed of SPI bus (00 is fastest @ 4MHz, 11 is slowest @ 250KHz)
clr=SPSR;
clr=SPDR;
delay(10);
  delay(100);
  int index = 0;
  digitalWrite(CHIPSELECT,LOW); // enable the ChipSelect on the backpack
  delayMicroseconds(500);
  for (int i=0;i<8;i++) for (int j=0;j<8;j++)
    spi_transfer(data[index]);
      index++;
  digitalWrite(CHIPSELECT,HIGH); // disable the ChipSelect on the backpack
And this one, nicked from justin's bike light code from here http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1234580222/15
Quote
/* define constants */
#define DATAOUT     11 //MOSI
#define DATAIN      12 //MISO // NOT USED
#define SPICLOCK    13 //sck
#define SLAVESELECT 10 //ss
#define WAIT         50 // min delay between frames.
#define BLACK 0
#define RED 1
#define GREEN 2
#define ORANGE 3
char out_buffer[64];    // output buffer for led matrix
// here are the bitmaps that the various modes use.
byte BACKGROUND[] = {
 B11111111,
 B11111111,
 B11111111,
 B11111111,
 B11111111,
 B11111111,
 B11111111,
 B11111111
byte X [] = {
 B11100111,
 B01000010,
 B00100100,
 B00011000,
 B00011000,
 B00100100,
 B01000010,
 B11100111
Write image to output buffer.
Should be preceeded by a call to fill_buffer()
void write_buffer(){
 digitalWrite(SLAVESELECT,LOW); // enable
 delay(5);
 for(int i = 0; i < 64; i++){
   shiftOut(DATAOUT, SPICLOCK, MSBFIRST, out_buffer);
 digitalWrite(SLAVESELECT,HIGH); // disable device
 delay(5);
Fill a buffer usting bitmap (data) in the specified color
Bit locations with a 0 are untouched so layers can be added consecutivly
A call to fill_buffer() should preceed write_buffer.
The buffer is filled first to avoid timing errors involved in non-sequential writes
void fill_buffer(byte* data, int color){
 byte bit;
 for (int i = 0; i < 8; i++)
   for(int j = 0; j < 8; j++){
     bit = data[7 - i] >> j & B0000001;
     if(bit){
       out_buffer[i * 8 + j] = color % 4;
Initialize pins and modes, calibrate.
void setup(){
 pinMode(DATAOUT, OUTPUT);
 pinMode(DATAIN, INPUT); // NOT USED
 pinMode(SLAVESELECT,OUTPUT);
 digitalWrite(SLAVESELECT,HIGH); //disable device
Get current mode, display current mode, pause.
void loop(){
 fill_buffer(BACKGROUND, BLACK);
 fill_buffer(X, RED);
 write_buffer();
 delay(WAIT);
Cheers for anything you can help me with, i just want simple colours to show so i can move on to the next stage.
Ryk
Logged
Pages: [1]   Go Up
Print
Jump to:
