Loading...
Pages: [1]   Go Down
Author Topic: 2560 total current draw  (Read 426 times)
Offline Offline
Newbie
View Profile
I'm planning on using a 2560mega  to manage a control panel for a machine tool, which will have multiple
indicators. I want to use high-intensity LEDs, which draw 30-50 ma each. The spec sheet says 40 ma max per output pin, but I've seen nothing about total current draw allowable for the chip - essentially, how many simultaneous LEDs can I light up at one time, assuming 30 ma each?
Relatedly, I will need a small amount of 5V power for other peripherals; how much current can the 2560 on-board regulator supply?
Thanks
ldw
Logged
France
Offline Offline
Sr. Member
View Profile
the best to do is to use anotoher external source of power (like computer psu) and use it to draw the current.
At this point arduino will juste be used to drive your components.
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
Well it's in the data sheet.
The answer is 200mA.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
The regulator is only good for 500-800mA.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Brattain Member
View Profile
WWW
Quote
There is also a heat issue so it depends on the input voltage:-
http://www.thebox.myzen.co.uk/Tutorial/Power_Examples.html
Logged
Pages: [1]   Go Up
Print
Jump to:
