Topic: Sensor trouble!?!?(SOLVED) (Read 2804 times) previous topic - next topic
vishalapr
May 02, 2011, 12:33 pm Last Edit: May 02, 2011, 04:55 pm by vishalapr Reason: 1
I just bought this sensor :
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150570236665&ssPageName=STRK:MEWNX:IT
Could someone tell me how to wire this thing up as it has 5 pins and not 3.
And could you give me some test code to run with this...
Thanks a lot
AWOL
Didn't it come with a datasheet?
That could be an expensive cheap sensor.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
vishalapr
AWOL
You could try wiring like an SRF04, which it resembles.
Otherwise, nope on help.
vishalapr
Ya I have wired it up but dont know where the Echo pulse output and trigger pulse input go because in many tutorial these ultrasonic sensors only have 3 pins 1 to - 1 to + and I to arduino. But now if I connect 2 to arduino is the code going to be different if yes what is the test code going to be...
Thanks
AWOL
The SRF04 has five pins, which is why I mentioned it.
vishalapr
I could not understand the schematic. Could you just give me some tips on how to write a program that with read the input from the sensor and echo the output to the screen where I can see it...Please as I really cannot understand a thing when I see the schematic, I just think its too complicated for a 13 year old like me
AWOL
http://www.robot-electronics.co.uk/htm/srf04tech.htm
You could try googling SRF04 and Arduino.
BTW, the spec on the eBay page said the device was IP65 rated.
I hope you're not depending on that.
vishalapr
Code: [Select]
IP65 rated
What dies that mean
vishalapr
Problem solved : with these two links
1)http://www.robot-electronics.co.uk/files/SRF04.pde
2)http://www.robot-electronics.co.uk/htm/arduino_examples.htm#SRF04%20Ultrasonic%20Ranger
Thanks
AWOL
If you don't know then you're probably not concerned.
It's an enironmental sealing rating - it is supposed to be proof against dust and directed spray.
I doubt very much that it is.
