Topic: Using IR Proximity Sensor to control motors (Read 3753 times) previous topic - next topic
Silent Siren
Hi all, I'm struggling to use the output of my IR sensors(2 sensors) to control 2 motors.
I am using 2 Sharp IR GP2Y0D340K Distance sensor , a Ardumoto to power the motors and a Arduino Uno. When I connect power to the Arduino the motors turn as expected , but only keep turning in one direction. I want the motors to change direction when the IR sensor detects an object, but they do not respond to the sensors. In my code I have assigned the sensors readings( 1 or 0 ) to be sent to the serial monitor just so that I can see if they are working, and they are. Can someone please take a look at my code and why the motors do not respond. Thanks in advance.
int pwm_a = 3;  //PWM control for motor outputs 1 and 2 is on digital pin 3
int pwm_b = 11;  //PWM control for motor outputs 3 and 4 is on digital pin 11
int dir_a = 12;  //dir control for motor outputs 1 and 2 is on digital pin 12
int dir_b = 13;  //dir control for motor outputs 3 and 4 is on digital pin 13
  pinMode(pwm_a, OUTPUT);  //Set control pins to be outputs
  pinMode(pwm_b, OUTPUT);
  pinMode(dir_a, OUTPUT);
  pinMode(dir_b, OUTPUT);
   analogWrite(pwm_b, 220);
   analogWrite(pwm_a, 220);
   int sensorValue = digitalRead(A0);
   int sensorValue1 = digitalRead(A1);
   Serial.println(sensorValue1, DEC);//Just to see if the sensors are working, and they are
  if (sensorValue = 0) {            //Sensor 1 is asigned to only control the left-side motor
   void LFORWARD();
    else{
   void LREVERSE();
  if(sensorValue1 = 0){           //Sensor 2 is asigned to only control the right-side motor
   void RFORWARD();
    else{
   void RREVERSE();
void LFORWARD();{
  digitalWrite(dir_a,HIGH);//Control for the left-side motor
void RFORWARD();{
  digitalWrite(dir_b,HIGH);//Control for the right-side motor
void LREVERSE();{
   digitalWrite(dir_a,LOW);//Control for the left-side motor
void RREVERSE();{
  digitalWrite(dir_b,LOW);//Control for the right-side motor
wildbill
This:
Should be this:
  if (sensorValue == 0)
Silent Siren
Thanks wildbill but the change didn't work. In the place of the motors I plased an LED to check if they would work, and they did work but the light emitted by them was really dim.
AWOL
Silent Siren
Thanks AWOL but by removing the semicolons it doesn't want to compile, sorry, what do you think is wrong?
AWOL
I think that this version of C doesn't like nested function declarations.
Move the functions out of loop, and LOSE THE SEMICOLONS.
