Loading...
Pages: [1]   Go Down
Author Topic: Control 230V dimmable bulbs  (Read 523 times)
Offline Offline
Newbie
View Profile
Hello,
To complete a lightning project I'll need to control 3 circuits each with with different kind of dimmable bulbs, I've no major issues on programming, but what for interfacing Arduino with 3 independent 230V controllers ?
Thanks a lot.
Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
Do you have a specification on controllers or link to ?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Basically you need to send some PWM signals out to the controllers. However, depending on what the controller needs you might have to put the PWM signal trough a transistor.
Logged
SW Scotland
Offline Offline
Edison Member
Arduino rocks
View Profile
3 off SSRs rated for logic level input.  Then drive them using PWM
Logged
Spain
Offline Offline
Newbie
View Profile
I have the same problem with my project. I think you should use a high-voltage transistor, but i don't know which one. There are lots of different types of transistors, and i only know about low-voltage ones.
If somebody knows something about what type of transistor could we use... smiley-confuse
Logged
SW Scotland
Offline Offline
Edison Member
Arduino rocks
View Profile
On the basis that the lamps are 230 volt AC you cannot use a transistor - they are DC only.  For this application you would need a triac.  However, considering that one is working with lethal voltage levels and the skill or knowledge levels are minimal (or non-existant) then using SSR devices as the interface is the safest way to go.  These are relatively inexpensive (compared to either funeral costs or house rebuilding)
See the attached as an example.
http://cgi.ebay.co.uk/Relay-3-Amp-SSR-Solid-State-RP1A23D3-Carlo-Gavazzi-NEW-/230614964838?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item35b1b91a66
E-bay sellers have lots of different rated units but the above is neat and possibly suitable for your application
SSRs have relatively slow turn-on  and turn-off characteristics so rather than using the fast Arduino PWM output you may have to create your own PWM signal with relatively low switching speeds.  Anything around 25Hz will not be noticable to the average human eye.
« Last Edit: May 03, 2011, 08:02:54 am by jackrae » Logged
Offline Offline
Brattain Member
View Profile
WWW
The problem is that the SSR only can turn on every cycle so if you give them anything faster than the mains (50 or 60HZ) then it will be on all the time. Anything slower and there will be erratic flickering as there will be a beat between the PWM and the mains.
Some SSRs are meant to be dimmed, these are called phase angle controllers. You generate PWM and then smooth it so it is DC before applying it to the SSR input. Some SSRs require 10V so you need to pass the PWM through a transistor before smoothing it and applying it to the SSR.
(SSR - Solid State Relay)
Logged
Offline Offline
Newbie
View Profile
Not yet and it's part of my issue as there are a lot available with diferent specs, nothing found specific for Arduino.
Logged
Spain
Offline Offline
Newbie
View Profile
Thank you very much for the information. I didn't know anything about SSR (nor its existance). I've been searching something about these components and i found a lot with many different prices.
Does SSR operates like a normal (electromechanic) relay? If I generate a PWM signal, can i connect it directly to the SSR in order to take control of the output signal (AC)?
Sorry if my english level is bad. I hope you understand me.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
No these devices are universal, most makers of them have never heard of the arduino.
Quote
No it uses a device called a Triac.
Quote
No. Only some SSRs have phase angle control. Then it needs the PWM filtering before feeding it into the SSR. See this link all about PWM:-
http://www.thebox.myzen.co.uk/Tutorial/PWM.html
Quote
This link shows some:-
http://uk.farnell.com/jsp/search/browse.jsp;jsessionid=WAHSKPFBJVUQWCQLCIPZNFQ?N=0&Ntk=gensearch_001&Ntt=SSR+phase+angle&Ntx=mode+matchallpartial&suggestions=false&ref=globalsearch&_requestid=717784
They are expensive because they will handle a lot of current. There are cheaper devices that handle less current. Depending where you are in the world look at your local electronics distributor.
Logged
Pages: [1]   Go Up
Print
Jump to:
