Topic: Ultrasonic waterproof sensors...how to getting work? (Read 3055 times) previous topic - next topic
jackalope
Hi guys
i bought these sensors:
http://www.emmeshop.it/index.php?main_page=product_info&cPath=190_191&products_id=3602
unfortunately on the website there isn't a datasheet and i think i cannot connect directly pins fomr sensors to arduino..
actually i've used parallax ping))) to create a parking sensor...and it works..but parallax ping))) are not waterproof...so
do you have an idea to use the WP sensor i bought? do you have a tutorial to build some type of breakout board to use them?
thanks
regards
Simon
AWOL
If they're 40kHz devices, I'd probably buy something like an SRF04, unsolder the transducers fitted and solder in some short flying leads to these devices.
Ultrasound from scratch isn't easy, unless you have access to an oscilloscope and some amplifier skills.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
jackalope
Hi AWOL
you mean i should unsolder Rx/TX from parallax ping))) board and try to solder my new waterproof TX/RX to parallax board and try it?
yes they are 40kHz...
thanks
Radames
hey AWOL, have you ever tried it before? do you know what can it result? the reached range change? how do you calculate the distance, you must know the sound velocity on this medium, isn't it?
AWOL
Are you trying to use them in water?
Around 1500m/s, off the top of my head.
Different for salt and fresh water.
jackalope
i dont' want to use them in water :D but on my car
however AWOL is it correct what i wrote in my second post?
thanks
regards
AWOL
If I had no other way of finding out, that's what I'd do.
Depends how much you can afford.
