Loading...
Pages: [1]   Go Down
Author Topic: Axle with motors  (Read 234 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I am looking for the ability to control an axle with 2 electric motors either side of it. I have a servo to rotate it, however I am not sure how to mechanically link the 2, I would imagine the servo would have a pinion gear put on it that would drive a pinion gear on the axle, but does anyone know where to get axles with pinion gears already mounted on them?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Go on give us a clue as to what you are doing?
Servos do not normally rotate more than 360 degrees, those that do are not servos.
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
I am building an airship similar to Blimpduino. I am aware most servo's only rotate 180 degrees however I was going to get around this by using a 2:1 pinion gear ratio (same way Blimpduino gets around it).
What I don't have is an axle that has a pinion gear on it that I can turn, in Blimpduino they use a Lego axle but I can't do that in mine because I have heavier motors and a greater length axle.
Logged
Pages: [1]   Go Up
Print
Jump to:
