Loading...
Pages: [1]   Go Down
Author Topic: need 13 outputs from arduino uno  (Read 1205 times)
Offline Offline
Full Member
View Profile
I'm working on a project that requires thirteen outputs (LEDs and a push-button), and I was wondering, is there any way to turn the analog pins or pins #1 and 0 (TX and RX, respectively) into regular digital output pins?
Logged
Copenhagen, Denmark
Online Online
God Member
Have you testrun your PDE file today?
View Profile
Yes to everything. The analog pins work as digital, if you address them as 14, 15 ..., ie digitalWrite(14) will output on analog 0. (Remember to set pinMode() first, of course)
pin 0 and 1 work fine as digital pins ... as long as you do not use the USB or Serial stuff. Usually they are not used as plain digital pins.
Logged
Offline Offline
Full Member
View Profile
Awesome, thanks a lot!
Logged
Manchester (England England)
Online Online
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
As that includes uploading a sketch it is quite difficult not to use them. You can always switch out those pins when doing the uploading like I did on this project:-
http://www.thebox.myzen.co.uk/Hardware/MIDI_Shield.html
Logged
Pages: [1]   Go Up
Print
Jump to:
