Thanks Eugene and Lauszus for the advice, I fully understand now why the IMU should be as close as possible to the axis of rotation.
However, I am quite close to achieving balance with the current setup, I am kinda short on time to move the IMU to the lower deck as the project deadline is fast approaching... Or am I just wasting my time trying to achieve balance with the IMU located where it currently is?? (about 50mm above the axis of rotation in the vertical direction)
My current stumbling block is finding the correct PID parameters.. I am using the original coding as posted by Kas in the initial thread on this topic
Am I correct in thinking that I should tune the terms in this manner. Tune Kp value first then Ki value then the Kd value and finally the "outside" K value? The coding I am referring to shown here:
float K = 1.4;
int Kp = 3;
int Ki = 1;
int Kd = 6;
int last_error = 0;
int integrated_error = 0;
int pTerm = 0, iTerm = 0, dTerm = 0;
int updatePid(int targetPosition, int currentPosition) {
error = targetPosition - currentPosition;
pTerm = Kp * error;
integrated_error += error;
iTerm = Ki * constrain(integrated_error, -GUARD_GAIN, GUARD_GAIN);
dTerm = Kd * (error - last_error);
last_error = error;
return -constrain(K*(pTerm + iTerm + dTerm), -255, 255);
I will try to post a video today to show the stage of balancing that I am at!
Any advice appreciated! Thanks guys!
