Topic: help with Duemilanove + Ethernet W5100 (Read 1 time) previous topic - next topic
nandoestevam
Hello Guys,
Sorry, my English don't is very well. But I try.
I'm have issues to do torn ON and OFF two LEDs.
When I turn ON ledPin 4 and I want turn ON ledPin 5, the ledPin 4 turn OFF.
I know that my code have some error.
Does they to help me?
The code whith ONE LED(It Works):
#include <String.h>
#include <Ethernet.h>
#include <SPI.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = {
  192, 168, 1, 243 };                       // Endereco IP
byte gateway[] = {
  192, 168, 1, 10 };                    // IP roteador
byte subnet[] = {
  255, 255, 255, 0 };                   //Mascara
Server server(80);                                      //Porta
byte sampledata=50;            //some sample data - outputs 2 (ascii = 50 DEC)
int ledPin = 4;  // Pino do Led utilizado
//char link[]="http://192.168.1.243/"; //link data
String readString = String(30); //string for fetching data from address
boolean LEDON = false; //LED status flag
void setup(){
  //iniciar Ethernet
  Ethernet.begin(mac, ip, gateway, subnet);
  //Set pin 4 to output
  pinMode(ledPin, OUTPUT);
  //enable serial datada print
void loop(){
  // Cria uma conexao cliente
  Client client = server.available();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        //read char by char HTTP request
        if (readString.length() < 30)
          //store characters to string
          readString += c;
        //output chars to serial port
        Serial.print(c);
        //if HTTP request has ended
        if (c == '\n') {
          //lets check if LED should be lighted
          if(readString.indexOf("L=1") >=0)
            //led has to be turned OFF
            digitalWrite(ledPin, LOW);    // set the LED off
            LEDON = true;
          else{
            //led has to be turned ON
            digitalWrite(ledPin, HIGH);    // set the LED on
            LEDON = false;
          // now output HTML data starting with standart header
          client.println("Content-Type: text/html");
          client.println();
          //set background to yellow
          client.print("<body style=background-color:white>");
          //send first heading
          client.println("<center>");
          client.println("<font color='blue'><h1>Casa Inteligente</font></h1>");
          //output some sample data to browser
          //client.println("<font color='blue' size='5'>Sample data: ");
          //client.print(sampledata);//lets output some data
          //drawing simple table
          //client.println("<font color='green'>Simple table: ");
          //printing some link
          client.println("<table border='1'><tr>");
          client.println("<td>");
          client.println("<h1><font color='blue'>Luz do Quintal</h1>");
          //controlling led via checkbox
          //address will look like http://192.168.1.243/?L=1 when submited
          client.println("<form method=get name=LED><input type=checkbox name=L value=1>LUZ<br><input type=submit value=Aplicar></form>");
          client.println("<br><font size='1'>(1=ON / 0=OFF)<br>");
          //printing LED status
          client.print("<font size='5'>Status: ");
          if (LEDON)
            client.println("<font color='green' size='5'>ON");
            client.println("<font color='red' size='5'>OFF");
          client.println("</center>");
          client.println("</td>");
          client.println("</tr></table></center>");
          client.println("</body></html>");
          //clearing string for next read
          readString="";
          //stopping client
          client.stop();
And the code whith problem(usin two leds(led and fan in my code):
#include <String.h>
#include <SPI.h>
byte mac[] = {
byte ip[] = {
byte gateway[] = {
byte subnet[] = {
int ledPin = 4;
int fanPin = 5;      // Pino do Led utilizado
boolean LEDON = false;//LED status flag
boolean FANON = false;
void setup(){
  //iniciar Ethernet
  pinMode(fanPin, OUTPUT);
void loop(){
  if (client) {
          readString += c;
        Serial.print(c);
        if (c == '\n') {
            LEDON = true;
          else{
            LEDON = false;
          if (c == '\n') {
          if(readString.indexOf("F=1") >=0)
            digitalWrite(fanPin, LOW);    // set the LED off
            FANON = true;
          else{
            digitalWrite(fanPin, HIGH);    // set the LED on
            FANON = false;
          client.println();
          if (LEDON)
          client.println("<h1><font color='blue'>Ar do Quarto</h1>");
          client.println("<form method=get name=FAN><input type=checkbox name=F value=1>Ar-Condionado<br><input type=submit value=Aplicar></form>");
          if (FANON)
          client.println("</tr></table></center><br>");
          readString="";
          //stopping client
          client.stop();
Please, help me...  :)
