Topic: Speaker advice using wave shield. (Read 2083 times) previous topic - next topic
Jodpers
Hi I was wondering is anyone here has any advice on how I would play audio through some speakers using the wave shield. The audio needs to be slightly louder then speaking volume. I have tried using an audio amp (6 to 16v) and this will work ok but as you can see it requires a lot of volts. I was wondering of a way to power some speakers off the 5 volts provided by the arduino?
CrossRoads
Use a transistor to control the speaker vs arduino pin directly.
5V peak to peak across a 4ohm speaker would yield P=V^2/R = 6+watts, yes?
I use a simple MOSFET amplifier to make some decent volume out of a 2", 4 ohm speaker that I got for $1.49 fro mpja.com, but I also run it from 12V.
I also have a sample of an H-bridge chip based board that I've been looking to try out, will send some details when I get home if the developer doesn't answer first.
Jodpers
Hi thanks for the reply!
so are you suggesting using the transistor as an amp eg. positive speaker output to base of transistor, collector to the 5 volts then emitter to ground?
Thanks again!
J
CrossRoads
I wired mine up like this.
since I was looking for GND to +Supply swing if 0-5v signal coming in, I didn't bother with proper input biasing like this:
