Topic: RF link display using the ATtiny85 (Read 22994 times) previous topic - next topic
carl47
I wanted to display my weather station data in other rooms in my house without using wires:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1291352241/3#3
I chose a simple and cheap(AUD5.6 for tx/rx pair) 433.92 MHz link:
http://littlebirdelectronics.com/products/433mhz-rf-link-kit
They are really only meant for things like a garage door controller.
The frequency response is very limited, I run them at 2000 b/sec.
I use VirtualWire(modified) library for the Transmitter which uses a ATmega328:
http://www.open.com.au/mikem/arduino/VirtualWire.pdf
//Transmitter. Sends integer as 2 bytes once per second
#include <VirtualWire.h>
#undef round
uint16_t data =0;  //the integer to send
    vw_set_tx_pin(4);
    vw_setup();    // 2000 Bits per sec
    data +=1;
    uint8_t number[2] ;
    number[0] = data;
    number[1] = data >> 8;  //send 2 bytes
    vw_send(number, 2);
    vw_wait_tx(); // Wait until the whole message is gone
    delay(1000);  //send every second
I further modified this library to get VirtualWireTiny library to work with the ATtiny85.
It handles receive only at 2000 b/sec.
The display is 4 digits of 7 segments. I use my SEVENtiny library.
http://arduino.cc/forum/index.php/topic,7866.0.html
The receive code is very simple for the ATtiny85 RX:
//Receiver. Waits to receive two bytes. Displays the integer.
#include <SEVENtiny.h>
#include <VirtualWireTiny.h>
#undef round
    vw_set_rx_pin(3);
    vw_rx_start();       // Start the receiver PLL running
}//end of setup
    uint8_t buf[VW_MAX_MESSAGE_LEN];//message length defined as 12 bytes
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
         uint16_t data = buf[1];
         data =(data << 8) | buf[0];
         SEVENtiny.displayI(data);
         vw_rx_stop();
     }//end of got data
}//end of loop
This code only uses 1756 bytes of Flash.
To program the ATtiny85 I use:
http://arduino.cc/forum/index.php/topic,59968.0.html
The lfuse must be set to 0xE2.
Download tinyRFlink.zip from:
http://code.google.com/p/mysudoku/downloads/list
theepdinker
Cool project!
I can think of some ways to use an affordable RF link at 2000 b/s
Occasional activity,
sporadic progress
carl47
Thanks theepdinker.
It does have some limitations like I cant use it to monitor my Oregon weather station.
It uses 433.92 but needs a 10 kb/s to get an output.
WEBAFF
Why you used modified library for the ATmega328 Transmitter? This lib works on it perfectly (at least for me.).
carl47
Yes it works perfectly for me to when I use a 328(with xtal) to TX and a 328(with xtal) to RX.
When I used a ATtiny85 with an internal clock for RX I got a lot of dropouts.
I guessed it was because the setting of Timer1 in VirtualWire was not quite right.
I tried using Timer2 in the 328 transmitter and this seemed to give much more reliable results.
Coding Badly
Did you "tune" the internal clock?
carl47
Thanks for you reply.
Thats a reasonable response to a fixed frequency error. OSCCAL can be set to change the internal oscillator frequency.
VirtualWire works by setting a timer to give a fixed frequency interupt. 62.5 usec is the default.
Compare mode to OCRA is used to generate the interupt.
OCRR1A default set is 125. So we could tune the bit rate using a set of OCR1A or OSCCAL.
The problem was that it was not a fixed frequency error. The transmission would work fine for many hours
and then have dropouts for an hour. It seemed to be ambient temperature related.
The frequency is temperature related as per Figure 22-41 of the data sheet.
With my change of ambient we should only have a change from 7.93 to 7.95 Mhz.
This should not be enough to cause problems to VirtualWire unless the origional TX frequency is
on the edge of the default 62.5 usec value.
When I changed the transmitter to timer2 with 62.5 usec interupts the problem was solved.
Having solved my problem I did not chase down any further answers like provided in your reply.
Cheers.
mingd
Hi carl47, thanks for the very handy post. I'm trying to use your library but get a bunch of errors when I compile the transmitter example. The receiver example compiled fine. I tried replacing the entire VirtualWire library with your version and also tried replacing just the 2 .cpp and .h files and I'm not quite sure what else to do. Any advice would be greatly appreciated!
Error messages;
...VirtualWire.cpp: In function 'void vw_setup()':
...VirtualWire.cpp:257: error: 'TCCR2A' was not declared in this scope
...VirtualWire.cpp:258: error: 'TCCR2B' was not declared in this scope
...VirtualWire.cpp:259: error: 'OCR2A' was not declared in this scope
...VirtualWire/VirtualWire.cpp:262: error: 'TIMSK2' was not declared in this scope
...VirtualWire/VirtualWire.cpp:268: error: 'DDRD' was not declared in this scope
... VirtualWire/VirtualWire.cpp: In function 'void vw_tx_stop()':
... VirtualWire/VirtualWire.cpp:299: error: 'PORTD' was not declared in this scope
... VirtualWire/VirtualWire.cpp: In function 'void TIMER2_COMPA_vect()':
... VirtualWire/VirtualWire.cpp:409: error: 'PIND' was not declared in this scope
... VirtualWire/VirtualWire.cpp:426: error: 'PORTD' was not declared in this scope
...VirtualWire/VirtualWire.cpp:428: error: 'PORTD' was not declared in this scope
carl47
Sorry I took so long I have been on holidays.
I have the folders:
SEVENtiny
VirtualWire
VirtualWireTiny
In the arduino librarys folder:
C:\arduino-0021\arduino-0021\libraries
The transmitter compliles OK for me.
There is a big problem when we use modified librarys along with new functions.
Its hard to keep everything in order. Checkout microsofts .dll hell for example.
Sorry it does not work. I no longer use any version of virtual wire I wrote my own library.
http://arduino.cc/forum/index.php/topic,63755.0.html
This does not have problems with compilation.
mingd
Thanks for the reply carl47. It was actually my oversight because I didn't set the appropriate board before compiling. Your other library sounds good and am keen to have a play. Hope you had a good holiday :)
mingd
Hi carl47, the VW transmitter code works well on the Arduino but I'm having some trouble getting the receiver bit working on the ATtiny85. I've modified the code to blink an LED when data is received but nothing happens.
I'm using the same pair of RF modules and the MIT method (http://hlt.media.mit.edu/?p=1229 ) of programming the tiny. Is the issue that we're using different cores?
carl47
I had a look at MIT's attiny45_85.zip .
It's written by the same bloke David A. Mellis, however my copy of the core is quite different.
The core that I use is in the Manchester.zip.
Have a try with my core and see.
When I get a problem like this I forget about the final project and go back to basic switch LED on/off.
Then add tiny bits of the final program.
Just a thought.
Coding Badly
Minor correction ... he spells his name Alessandro Saporetti.  (David Mellis updated the package for Arduino 0022)
I normally would not mention it but Alessandro really does deserve credit for his work.
carl47
#13
Oct 26, 2011, 05:40 am Last Edit: Oct 26, 2011, 05:54 am by carl47 Reason: 1
I,m very sorry to leave out Alessandro's name.
However in the MIT core I could only find:
Copyright (c) 2007 David A. Mellis
Copyright (c) 2008 David A. Mellis.  All right reserved.
Copyright (c) 2005-2006 David A. Mellis
The core which I use comes from the site you list:
http://code.google.com/p/arduino-tiny/
In the core from arduino-tiny-0022-0008.zip I could only find:
Copyright 2010 Rowdy Dog Software.
Copyright (c) 2006 Nicholas Zambetti.  All right reserved.
Copyright (c) 2010 Hernando Barragan.  All right reserved.
Coding Badly
Alessandro marked only the files he modified (pins_arduino.c, pins_arduino.h, WInterrupts.c, etcetera) (A.Saporetti and Saposoft).
His credit is also in that core in the same places.
I do need to apologize.  In my mind, it is Alessandro's core because he is responsible for getting it to work on the ATtinyX5 processors.  The reality is that the core is the product of many people (including, of course, David Mellis).  It is a shining example of what open source is meant to be.  So, I apologize to David Mellis and Hernando Barragan.  By emphasizing Alessandro's contribution I did not mean to diminish your contributions.
