Loading...
Pages: [1]   Go Down
Author Topic: how to establish rf communication btw two arduino boards\  (Read 1034 times)
Offline Offline
Newbie
View Profile
am doing a project on swarm robotics...and i have to establish rf communication btw two robots...board used is arduino uno and communication module is HR-1001.......can anyone tell me how to do it...am tired of experimenting......
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
Now the cynic in me hears "I can't be bothered / my deadline is near, can someone else do my assignment?"
Show us what you've done, and what went wrong.
Quote
You'll have to do better than that:
http://www.google.co.uk/search?sourceid=navclient&hl=en-GB&ie=UTF-8&rlz=1T4ADFA_enGB391GB391&q=HR-1001
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Offline Offline
Newbie
View Profile
Oh it's pretty easy. Here's how:
http://tinyurl.com/68u6ull
Logged
Offline Offline
Newbie
View Profile
i tried wat u hav told....i downloaded virtual wire...added it to library....connected tx and rx of hr-1001 to digital i/o pins 11 and 12 of arduinoand gnd and 5v supply was also connected.......and loaded an example code...still itz not wrking.......wat may b the problem....can anyone help me wid this.....
Logged
Offline Offline
Newbie
View Profile
I'm not trying to troll or anything but P L E A S E write in proper English, or if you can't (which totally understandable, it's not like you are required to learn English) spell-check what you write before you post...
Things like "wat" "hav" "itz" "wrking" "wid" would have been marked as incorrect.
Anyway back to your problem.
You need to elaborate a bit more on the "It's still not working" part.
Which part is not working? The receiver? The transmitter?
Logged
Offline Offline
Newbie
View Profile
we connected transmitter and receiver pins at digital output pins 12 and 11..also connected ground and vcc pins...virtual wire library is downloaded..recevier and transmitter codes are loaded....data what is transmitted is not received..is it because hr-1001 is not compatible for this???
Logged
Offline Offline
Newbie
View Profile
Logged
Global Moderator
Boston area, metrowest
Online Online
Brattain Member
Available for Design & Build services
View Profile
WWW
This is the part you are using?
http://www.ohglrf.com/upload/2010330191534162_0.pdf
Post a schematic of what you have hooked up, jumpers on the modules, antennas, etc. and your code listing.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Offline Offline
Newbie
View Profile
thanks...but i have this manual......it is told that we can use hr-1001 without shorting any pins at a baudrate of 1200 and a frequency of 430mhz...isn't it????so i didnt short any pins of hr-1001 and i directly connected like receiver to transmitter and transmitter to receiver and also vcc and gnd...
this was not working..so i downloaded virtual wire and receiver and transmitter wire to digital pins of arduino..and loaded example codes of transmitter and receiver and i transmitted a word 'hello'..but the other arduino was not receiving....
am just a beginner...please help me....
for receiver
// receiver.pde
// Simple example of how to use VirtualWire to receive messages
// Implements a simplex (one-way) receiver with an Rx-B1 module
// See VirtualWire.h for detailed API docs
// Author: Mike McCauley (mikem@open.com.au)
// Copyright (C) 2008 Mike McCauley
// $Id: receiver.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
#include <VirtualWire.h>
    Serial.begin(1200);   // Debugging only
    Serial.println("setup");
    // Initialise the IO and ISR
    vw_set_ptt_inverted(true); // Required for DR3100
    vw_setup(2000);    // Bits per sec
    vw_rx_start();       // Start the receiver PLL running
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
   int i;
        digitalWrite(13, true); // Flash a light to show received good message
   // Message with a good checksum received, dump it.
   Serial.print("Got: ");
   for (i = 0; i < buflen; i++)
       Serial.print(buf, HEX);
       Serial.print(" ");
   Serial.println("");
        digitalWrite(13, false);
for transmitter
// transmitter.pde
// Simple example of how to use VirtualWire to transmit messages
// Implements a simplex (one-way) transmitter with an TX-C1 module
// $Id: transmitter.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
    const char *msg = "hello";
    digitalWrite(13, true); // Flash a light to show transmitting
    vw_send((uint8_t *)msg, strlen(msg));
    vw_wait_tx(); // Wait until the whole message is gone
    delay(200);
Logged
Global Moderator
Online Online
Brattain Member
View Profile
WWW
Here's the problem then:
"use hr-1001 without shorting any pins at a baudrate of 1200"
yet you have VirtualWire set up for a different speed:
They need to be set to agree.
This line
only sets the comms via the USB port to your PC (which uses the serial D0/D1 lines).
Logged
Offline Offline
Newbie
View Profile
i changed the speed to 1200bits per sec........it is not even transmitting the data.....these are the connections i have done...transmitter of hr-1001 to digital i/o pin 12 of arduino....reciever to pin 11 of arduino...gnd and vcc......the code is same as above.....except that it is 1200bits/sec....an led was connected such that it'll glow when transmission is done....when we loaded the program and arduino was switched on...led was not glowing....
Logged
Offline Offline
Newbie
View Profile
sir....we done the transmission part...but it is not get receiving by the second robot...??what may be the problem???
we consulted the shop where we boought the components...he done the communication part...and when we tried it with our boards it was not working....
arduino boards are working....
Logged
Pages: [1]   Go Up
Print
Jump to:
