Topic: how to establish rf communication btw two arduino boards\ (Read 4162 times) previous topic - next topic
mithulnath
am doing a project on swarm robotics...and i have to establish rf communication btw two robots...board used is arduino uno and communication module is HR-1001.......can anyone tell me how to do it...am tired of experimenting......
AWOL
Now the cynic in me hears "I can't be bothered / my deadline is near, can someone else do my assignment?"
Show us what you've done, and what went wrong.
You'll have to do better than that:
http://www.google.co.uk/search?sourceid=navclient&hl=en-GB&ie=UTF-8&rlz=1T4ADFA_enGB391GB391&q=HR-1001
antonmorvolhert
Oh it's pretty easy. Here's how:
http://tinyurl.com/68u6ull
mithulnath
i tried wat u hav told....i downloaded virtual wire...added it to library....connected tx and rx of hr-1001 to digital i/o pins 11 and 12 of arduinoand gnd and 5v supply was also connected.......and loaded an example code...still itz not wrking.......wat may b the problem....can anyone help me wid this.....
antonmorvolhert
I'm not trying to troll or anything but P L E A S E write in proper English, or if you can't (which totally understandable, it's not like you are required to learn English) spell-check what you write before you post...
Things like "wat" "hav" "itz" "wrking" "wid" would have been marked as incorrect.
Anyway back to your problem.
You need to elaborate a bit more on the "It's still not working" part.
Which part is not working? The receiver? The transmitter?
mithulnath
we connected transmitter and receiver pins at digital output pins 12 and 11..also connected ground and vcc pins...virtual wire library is downloaded..recevier and transmitter codes are loaded....data what is transmitted is not received..is it because hr-1001 is not compatible for this???
mithulnath
CrossRoads
This is the part you are using?
http://www.ohglrf.com/upload/2010330191534162_0.pdf
Post a schematic of what you have hooked up, jumpers on the modules, antennas, etc. and your code listing.
mithulnath
thanks...but i have this manual......it is told that we can use hr-1001 without shorting any pins at a baudrate of 1200 and a frequency of 430mhz...isn't it????so i didnt short any pins of hr-1001 and i directly connected like receiver to transmitter and transmitter to receiver and also vcc and gnd...
this was not working..so i downloaded virtual wire and receiver and transmitter wire to digital pins of arduino..and loaded example codes of transmitter and receiver and i transmitted a word 'hello'..but the other arduino was not receiving....
am just a beginner...please help me....
for receiver
// receiver.pde
// Simple example of how to use VirtualWire to receive messages
// Implements a simplex (one-way) receiver with an Rx-B1 module
// See VirtualWire.h for detailed API docs
// Author: Mike McCauley (mikem@open.com.au)
// Copyright (C) 2008 Mike McCauley
// $Id: receiver.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
#include <VirtualWire.h>
    Serial.begin(1200);   // Debugging only
    Serial.println("setup");
    // Initialise the IO and ISR
    vw_set_ptt_inverted(true); // Required for DR3100
    vw_setup(2000);    // Bits per sec
    vw_rx_start();       // Start the receiver PLL running
    uint8_t buf[VW_MAX_MESSAGE_LEN];
    uint8_t buflen = VW_MAX_MESSAGE_LEN;
    if (vw_get_message(buf, &buflen)) // Non-blocking
   int i;
        digitalWrite(13, true); // Flash a light to show received good message
   // Message with a good checksum received, dump it.
   Serial.print("Got: ");
   for (i = 0; i < buflen; i++)
       Serial.print(buf, HEX);
       Serial.print(" ");
   Serial.println("");
        digitalWrite(13, false);
for transmitter
// transmitter.pde
// Simple example of how to use VirtualWire to transmit messages
// Implements a simplex (one-way) transmitter with an TX-C1 module
// $Id: transmitter.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
    const char *msg = "hello";
    digitalWrite(13, true); // Flash a light to show transmitting
    vw_send((uint8_t *)msg, strlen(msg));
    vw_wait_tx(); // Wait until the whole message is gone
    delay(200);
CrossRoads
Here's the problem then:
"use hr-1001 without shorting any pins at a baudrate of 1200"
yet you have VirtualWire set up for a different speed:
They need to be set to agree.
This line
only sets the comms via the USB port to your PC (which uses the serial D0/D1 lines).
mithulnath
i changed the speed to 1200bits per sec........it is not even transmitting the data.....these are the connections i have done...transmitter of hr-1001 to digital i/o pin 12 of arduino....reciever to pin 11 of arduino...gnd and vcc......the code is same as above.....except that it is 1200bits/sec....an led was connected such that it'll glow when transmission is done....when we loaded the program and arduino was switched on...led was not glowing....
mithulnath
sir....we done the transmission part...but it is not get receiving by the second robot...??what may be the problem???
we consulted the shop where we boought the components...he done the communication part...and when we tried it with our boards it was not working....
arduino boards are working....
