Topic: Touch Screen 8 Step Sequencer (Read 1 time) previous topic - next topic
joannnne
Hello,
I am currently working on an 8 step sequencer with a touchscreen and an LED matrix underneath. I am reading values from the touchscreen fine and everything is mapping well. Using LedControl.h I have been able to make the 'height' of an LED column represent the position of a touch along that column. I also have a speaker connected that I hope to play audio through. My intention is to make the frequency of the note dependent on the position of the touch along a column. Most of the sequencer tutorials I have found are using digital read to read inputs such as buttons (see code below). Can anyone suggest to me an appropriate method of achieving this?
#define N_PINS 2
const byte DigitalInSwitch [N_PINS] = { 2, 3};
for (int i = 0; i < N_PINS; i++) {
  if (digitalRead (DigitalInSwitch ) == HIGH)
    steps = analogRead(AnalogInFrequency);
    lastPushedStep = i + 1;
Many Thanks
Code copied from http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1272017881/8
WilliamK Govinda
HA! I was going to do the same thing a month ago, but I couldn't find any good sized LEDs matrix around here so I drop the whole thing out... ;-)
In any event, check the source-code for Beat707.com project, you will find some nice things there to help you out.
Wk
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
