Topic: arduino UNO with riverdi screen (Read 112 times) previous topic - next topic
LEI_JIN
I am trying to use riverdi display RVT50AQFFWC00 (MIKROE-2171) with arduino UNO.
The components I have are:
Arduino UNO
Riverdi click (MIKROE-2100)
Display Development Tools 5" Capacitive Riverdi Display, RVT50AQFFWC00 (MIKROE-2171)
I have the wiring schematic attached.
I wonder if this setting will work and is there a sample program to start with?
If not, what components I should choose, or how could I make the screen working.
The purpose of the project is the display a reading from encoder and reset the process from the screen.
Thanks for help.
TFTLCDCyg
#1
Mar 14, 2019, 10:59 pm Last Edit: Mar 15, 2019, 12:40 am by TFTLCDCyg
Your TFT is a 3.3V SPI device. Use this shield
The library of control can be this: gameduino 2/3
MCU: arduino UNO
TFT: Riverdi 5" FT813 (800x480 px)
LEI_JIN
TFTLCDCyg
#3
Mar 15, 2019, 06:33 pm Last Edit: Mar 15, 2019, 06:51 pm by TFTLCDCyg
Also you can use a MCU of 3.3V like an arduino due or teensy 3.2 or 3.5 or 3.6, or STM32: M4 Demo, F429ZI-Disco, Nucleo F767ZI or Core7XXI
Connect your TFT directly on SPI1.
You need this
- breakout 20 pin FPC 0.5 mm pitch like this or this
- FPC 20 pin 0.5 mm pitch (large: 5, 10, 12 or 15 cm)
STM32F103VE
Teensy 3.6
You can use this SD reader in parallel to SPI port of the TFT, but with a different SD-CS pin.
I recommend this wiring: pin 10 for TFT-CS and 5 for SD-CS on boards like teensy 3.X or arduino Due
For the TFT on STM32: SPI1
For the SD reader on STM32: SPI3 on F429-Disco or Nucleo F767ZI; SPI2 on M4Demo or Core7XXI
