Topic: Measuring capacitance of a dual cable with arduino (Read 393 times) previous topic - next topic
brkblbn
Can anyone help me???
How can I measure capacitance of a dual cable or any cable with arduino. I found this
https://circuits4you.com/2016/05/13/capacitance-measurement-arduino/ but this is just measuring the unknown capacitor.
jremington
#1
Mar 14, 2019, 10:15 pm Last Edit: Mar 14, 2019, 10:19 pm by jremington
If the cable has two leads, or an inner and outer conductor, use those two in the same circuit. Makle sure the wires are not connected at the far end.
You may have to change the resistor values, as the cable capacitance will usually be in the pF to nF range (unless it is quite long).
Hint: you can look up the capacitance per unit length for most cables and wiring. For example, 12 AWG "zip" cable for household lamps and audio speakers has capacitance of about 60 pF/meter.
brkblbn
First, Thank you for your message.
So, you say I keep the same circuit and source code but change capacitor with dual cables. Does it work
like that? I don't think that the measuring will be accurate.
jremington
#3
Mar 15, 2019, 12:01 am Last Edit: Mar 15, 2019, 12:02 am by jremington
Quote
Obviously, you have no basis for thinking that, until you have actually tried the experiment. Use a known capacitance for tests.
brkblbn
#4
Mar 16, 2019, 02:10 pm Last Edit: Mar 16, 2019, 02:14 pm by brkblbn
I tried to do the experiment but I do not understand how to implement the cables to the circuit. Connections may be wrong.
jremington
#5
Mar 16, 2019, 11:41 pm Last Edit: Mar 16, 2019, 11:43 pm by jremington
Quote
If the cable has two leads, or an inner and outer conductor, use two AT THE SAME END in the same circuit.
Make sure the wires are not connected at the far end.
https://learn.sparkfun.com/tutorials/capacitors/all
brkblbn
Thank you for your helpful advice but I already know how capacitor works. I just do not know implementing
the design using arduino :(
jremington
#7
Mar 17, 2019, 11:06 pm Last Edit: Mar 18, 2019, 12:25 am by jremington
Quote
No, you don't, because you don't understand that a cable with two or more leads IS a capacitor.
What is so difficult to understand about connecting two leads of a two wire cable to a circuit?
Maybe this picture will help:
brkblbn
#8
Apr 13, 2019, 05:01 pm Last Edit: Apr 13, 2019, 05:02 pm by brkblbn
My supervisor did not like the method he told me to do with TDR(Time Domain Reflectometry) so my new concern is:
I need a send a pulse to a cable(coax or simple copper wire) either sin/cos wawe or square. Then that
signal goes to end of the cable and reflected back to first position. After I understand the
exact(disconnection) open circuit location of the cable. For generating the signal can my oscillator in
arduino generate that kind of signal or I need to buy a new oscillator? And can I see the reflected signal
waweform from arduino software without an oscilloscope.
MarkT
TDR doesn't measure the cable capacitance, it measures its length (assuming the dielectric constant
is known, or vice versa).
You measure the cable's characteristic impedance, but that depends on the capacitance and
inductance per unit length.
Quote
[/qoute]
Rectangular pulse with very fast edges, the rise and falltimes limit the resolution.
Quote
Then that signal goes to end of the cable and reflected back to first position. After I understand the
The fastest edges an Arduino generate is perhaps 3 to 5ns risetime, good enough for a resolution of
a few feet, but it has no way to measure arrival time to better than the system clock period, and the
complication is that the return voltage can be 0V, 5V or 10V for a 5V pulse going in.
A TDR needs some high speed auxiliary circuitry, these days most 'scopes are fast enough to do the
measurement.
Normally you can just look up the cable capacitance in the specs for the cable...
brkblbn
I don't measure capacitance with TDR. I 'm gonna measure length of the cable then I put it into test. In
test I measure the "known" length of a cable then I'll check the length from the TDR, if lengths are not
match so I understand that there is a open circuit fault and tell the exact location. So according to you I
can't make that circuitry with arduino. How can I do that? Do I need osciloscope?
Idahowalker
#11
Apr 14, 2019, 04:54 am Last Edit: Apr 14, 2019, 04:55 am by Idahowalker
Have 'you' tried to do a search, using your favorite search engine with the words "arduino tdr"?
If you did you'd find this https://forum.arduino.cc/index.php?topic=183770.0 which is quite informative.
MarkT
Whoops, I got the quoting nesting wrong in my posting - I say that most 'scopes these days are fast
enough to do this (proper scopes, not toys).
