Topic: 328p board not working (Read 1 time) previous topic - next topic
SuperMiguel
So i bought an all in one controller: http://www.dfrobot.com/index.php?route=product/product&path=52&product_id=56 on the documentation it says to use the arduino IDE, so i used it, when trying to load code to it. I get this error: avrdude: stk500_recv(): programmer is not responding
pst i did select the right port and the right board.
SuperMiguel
connected an ICSP programmer to it, and cant even read the signatures :(
fuh
If you use the -F option what happens ?
http://creativecommons.org/licenses/by-nc-sa/3.0/
SuperMiguel
fuh
#4
May 07, 2011, 09:59 pm Last Edit: May 07, 2011, 10:22 pm by fuh Reason: 1
I assume COM11 is the ISP.
I see a USB port on the board, when you connect it what appears on the device manager ?
-edit-
Also try to use a more verbose output using -vvv.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
