Topic: error: expected unqualified-id before 'if' (Read 1 time) previous topic - next topic
May 07, 2011, 03:04 am Last Edit: May 07, 2011, 03:43 am by mlandergan Reason: 1
Hello everyone,
So I am working on some code for my robot. I have to ldr's on the front of the robot. It is connected to analog pins 0, 1. I'm still new to programming. When I compile the follow code I get:
Tank_with_ldr_:19: error: expected unqualified-id before 'if'
Tank_with_ldr_:26: error: expected unqualified-id before 'else'
Something got messed up when I pasted the code from the arduino ide, so the loop() wasn't part of it.
Code: [Select]
const int analogpin = 0;  // Analog input pin
const int analogpin2 = 1;
  Serial.begin(9600);   // initialize serial communications at 9600 bps:
  int adcvalue = analogRead(analogpin);    // read the analog in value:
  Serial.print("\ntemp sensor = " );
  Serial.print(adcvalue);    // print the adc value to the serial monitor:
  double temp = adcvalue / 25.6;  //convert it to Celsius
  Serial.print("\n temp = ");
  Serial.println(temp);   // print the temperature
  delay(1000);   // wait 1 second before next sample
  int lightSensorReading = analogRead(analogpin2);
  Serial.print("\nlight sensor: ");
The code at line 20 on is outside of any function where it can't exist.
