Loading...
Pages: [1]   Go Down
Author Topic: MOSFET's?  (Read 722 times)
East Coast USA
Offline Offline
Newbie
Hands in the air!
View Profile
WWW
Anybody have suggestions for MOSFET transistors that work with the 5V from an Arduino? I'm looking for something from DigiKey or Mouser.
I read that part# FQP50N06L from Fairchild was 'logic-level', but I am new to datasheets, and I'm not sure what to look for.
Thanks!
Logged
Build your own sentry gun! http://psg.rudolphlabs.com
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
You found the magic phrase, which is indeed "logic level". The key is to find a guaranteed value for Rds(on) when the gate voltage is 4.5V. For example, the NDP6060L:
http://www.fairchildsemi.com/ds/ND/NDB6060L.pdf
When searching at Digi-Key our Mouser use search options that limit the search to those MOSFET's which have guaranteed Rds(on) values at 4.5V and you should be finding all the logic-level MOSFET's.
The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, speaker, microphone, light sensor, potentiometer, pushbuttons
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
If you're driving lots of current, make sure you get a part with low Rds also, like down in the 8-10ohm (0.010 , 0.008) range. The lower you get, the cooler it will run.
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Copenhagen, Denmark
Offline Offline
God Member
Have you testrun your PDE file today?
View Profile
I've had good experience (a single project) with RFP30N06LE (coincidentally bought at Sparkfun)
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Can anyone recommend a good small LL FET? Say in a SOT23 package, 200mA or thereabouts. I seem to be having all sorts of trouble finding one.
______
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
0
Offline Offline
Faraday Member
ruggedcircuits.com
View Profile
WWW
How about a 2N7002? It's only <100mA but it's super-cheap. Otherwise, the IRLML2402 is a good choice: Rds(on) of 250mOhms at 4.5V gate voltage. Rated for 20V.
The DIN Rail Mount kit for Arduino: quickly attach your Arduino to standard DIN rail
Logged
Offline Offline
Tesla Member
View Profile
WWW
Thanks RC, they both look good.
______
Rob
Logged
Pages: [1]   Go Up
Print
Jump to:
