Loading...
Pages: 1 2 [3]   Go Down
Author Topic: Wiring a Z80 to Arduino...  (Read 3587 times)
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
D0..D7 is the Z80 data bus, just as A0..A15 is the address bus.
Logged
Global Moderator
UK
Offline Offline
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
Quote
I think it is the thought of wiring all that lot up more than anything else turned me on to microcontrollers!
My FYP was a 6800 controlled rover, and I damn near sprained my wrist wire-wrapping it.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
I don't get the D0-7
Quote
Doh, I must have written that before my first cup of coffee.
All the data lines should show 0v I would think, if that's not the case then the chip must be stuffed.
_____
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Full Member
The people the people they see me and they know
View Profile
This project sounds prime for an FPGA
Logged
Global Moderator
UK
Offline Offline
Brattain Member
View Profile
That would be cheating
Logged
Offline Offline
Newbie
View Profile
Hello !
Sorry for the long delay (delayWeeks(), a new Arduino function...  smiley), but
I was waiting for my Z80 - and other electronic stuff - from Jameco (which costed me 44 € for shipping PLUS
44 € for customs... ouch... never again !), and then I became father for the second time... So I'm just beginning
to have a little spare time for me again, before going back to work tomorrow (ouch again).
While waiting for the Z80, I made some tests with a 6502, and it worked perfectly. So, I've done the same tests
with the new Z80, and it works great.
- I've bought a 1Mhz oscillator, but it's too fast for the Arduino to keep up the pace, even with a basic test.
So I'm still using the Arduino as the source of CLK.
- The Arduino plays the role of an memory simulator (using the Arduino RAM for the Z80). For the time being,
I write my Z80 code and compile it on PC, then insert it into a byte array in the Arduino code.
(eg: char bytes[]={0x3E,0x20,0xD3,0,0x3C,0xC3,2,0};). Every time the Z80 requests a byte from memory, it is taken
from this array. Thank you Rob for the suggestion.
- It also serves as an I/O IC simulator : every time the Z80 outs a byte to 0, the Arduino sends it
back to the PC via Serial and then I can display it on my PC screen. I will use the same mechanism, in
the opposite direction, to provide a virtual keyboard to my Z80 computer.
Things I'd like to do now:
- use a real memory instead of the Arduino. Since I don't have an EEPROM programmer, I'm trying to use a NVRAM
but for now, it doesn't work (whenever I reset my circuit, some bytes - sometimes a lot- from the NVRAM get corrupted, don't know
why. Maybe a write occurs during the RESET with the WriteEnabled pin unstable ?). When it will work, I will set up a assembly chain,
so that I can write code on my pc, then assemble and download it into the NVRAM, with some kind of bootloader at the start of the
NVRAM (the Arduino will "listen" to IORQ queries on address X, and provide the data to the bootloader so it can write it into RAM - don't
know if I'm clear !?)
- use latches to provide more than 64 kbytes of memory (switching banks)
- connect a parallel 40x2 LCD display directly to the Z80, so it can output text by itself
- build or connect some kind of keyboard.
- connect some kind of mass storage. I've only a few ideas right now, like using the SPI interface of an SD-card.
- connect it to a VGA monitor. The tricky part for me, right now.
then...
- write an O/S (multitask would be great, but is it possible without hardware NMI ?) and maybe a compiler before (or use some kind of C compiler for Z80,
like SDCC)
- make it multi-processor
- etc, etc...
Well, that's a lot to do ! It will eventually require a few years...
Thank you again for your advices and help !
cr0sh : sorry, I did'nt have enough time to explain why I'm doing this.
- first, I didn't know you could still find DIP40 Z80 (I knew of the Rabbit one, but where's the fun ?)
- I'm not interested in repairing it to have it work (I've had a 6128 CPC Amstrad, in the 80's, and emulators are enough for me)
- it's really for the sake of the educational value : I've always wanted to design and build my own computer,
but I work in the software businness, which is a really separate world (when you don't work with embedded devices).
- I was sure the Amstrad was in bad condition. When people sell you this kind of stuff, at a very low price, and without
the power cord (because they "could'nt find it"), 99 % of the time it's because it's not working anymore.
Boz
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
