Topic: String as a function name ?? (Read 3209 times) previous topic - next topic
preejit
could someone suggest an alternate piece of code for this
  String c="loopk";
  c();
void loopk()
  Serial.print("strings can be used as function names");
AWOL
Quote
No they can't.
Tell us what you want to do, not how you think it should be done.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
preejit
i simply want to use a branch statement
AWOL
C doesn't have a branch statement.
You're going to have to tell us more.
preejit
its k .im using a mircorpocessor for the first time. just trying out simple programmes.. i was used to using branches in assembly language.. i think i can manage without. thanks anyway
nickgammon
Code: [Select]
String c="loopk";
  c();
You can't do that in assembler, but whatever.
Please post technical questions on the forum, not by personal message. Thanks!
More info:
http://www.gammon.com.au/electronics
nickgammon
Does it have a goto statement?
More info:
AWOL
Yes. But we don't talk about it in poilte circles.
nickgammon
Agreed. I have been programming for ... longer than I care to remember. You don't need branch or goto statements in modern code. It makes things incredibly obscure. If we taught you how to use them, next you will be complaining that your program doesn't work.
More info:
jraskell
And if you talk about it in impolite circles, you get beat up.
gardner
I think goto's have their place.  I've implemented plenty of FSAs as goto maps and they are easier to read and debug than transition tables and state variables.  I couldn't write more than a hundred lines without using break, continue and return, which are just particular flavours of goto.  I remember trying to code in Pascal and winding up with conditions spanning hundreds of lines, nested 8 or more deep, mainly because it wasn't allowed to branch out using a goto.  The resulting mess of extra nesting and spurious state-holding variables was worse, IMO.
Grag38
While the goto stuff exists in C language, there is no reason of not using it !
If it was'nt so good, it should have to disappear for a long time....
gardner
Well, as with anything, there are definitely circumstances where it is inappropriate to use gotos, just as torturing a for () into an if () and such can make things tough to follow.  Goto can technically be used to branch into the middle of control structures, but the resulting functionality is impossible to debug, and this is the type of thing that made folks close the door on it originally.  But C, and especially C++ are littered with stuff that is so limited in usefulness that I am not sure they should stay.  Bit-fields and structure return types are things I scratch my head at.  Digraphs are an outright menace.  Some people say that goto, also, aught to go, but I say oh no, it isn't so.  Judicious gotos, to and fro, are apropos and handy for the pro.
jraskell
Legacy support is a major sticking point in the C/C++ language.  My employer alone has hundreds of thousands of lines of code written decades ago that still compiles with Visual Studio 2010.  Add that to the thousands of companies out there with similar code bases, and any changes to the standard that could potentially render millions of lines of code uncompilable is met with incredible resistance.
johnwasser
Code: [Select]
  String c="loopk";
  if (c == "loopk")
    loopk();
void loopk()
There, I fixed it.  :)
Send Bitcoin tips to: 1G2qoGwMRXx8az71DVP1E81jShxtbSh5Hp
