Topic: Code for scrolling text by using max7219 to drive a 8x8 led matrix (Read 9391 times) previous topic - next topic
johnny-depp_165
Hello every1....i need a little help i m new in programming and coding so i need a code for scrolling text on a 8x8 led matrix using Max7219 and a arduino board i hav several codes for displaying text but i need the code for scrolling text if any1 know it plz post here thanks i m using the following circuit:
http://1.bp.blogspot.com/_7uyXRm_coS4/SJzZNBgesUI/AAAAAAAAALc/uH_pOGk4uoY/s1600-h/max7219.png
PaulS
Here's a clue: The difference between displaying text on a LED matrix and scrolling text on a LED matrix is the text.
Show this scrolling by...
how this scrolling by...S
ow this scrolling by...Sh
w this scrolling by...Show
this scrolling by...Show t
Figure out what text you want to display.
Display that text. Wait some period of time.
Alter the text.
Alter the text.
Alter the text.
Alter the text.
<repeat as often as desired/required>
johnny-depp_165
thx a lot its working the code becomes long but its works just fine thanks once again...
PaulS
Quote
The code should not become all that long, unless it was long to begin with. Altering the code to display shouldn't take but about 5 lines of code. Displaying the new text in a loop, in which you alter the code, should be simple.
Post the code you came up with, if you are using a loop. Otherwise, try using one.
johnny-depp_165
#include "LedControl.h"
Now we need a LedControl to work with.
pin 12 is connected to the DataIn
pin 11 is connected to the CLK
pin 10 is connected to LOAD
We have only a single MAX7219
LedControl lc=LedControl(12,11,10,1);
/* we always wait a bit between updates of the display */
unsigned long delaytime=250;
The MAX72XX is in power-saving mode on startup,
we have to do a wakeup call
lc.shutdown(0,false);
/* Set the brightness to a medium values */
lc.setIntensity(0,8);
/* and clear the display */
lc.clearDisplay(0);
void writeWWWWWWWWOnMatrix() {
/* here is the data for the characters */
byte w[8]={
B11111110,B00000100,B00001000,B00000100,B11111110,B00000000,B00000000,B00000000 };
byte a[8]={
B00000000,B11111110,B00000100,B00001000,B00000100,B11111110,B00000000,B00000000 };
byte q[8]={
B00000000,B00000000,B11111110,B00000100,B00001000,B00000100,B11111110,B00000000 };
byte c[8]={
B00000000,B00000000,B00000000,B11111110,B00000100,B00001000,B00000100,B11111110 };
byte s[8]={
B00000000,B00000000,B00000000,B00000000,B11111110,B00000100,B00001000,B00000100 };
byte y[8]={
B00000000,B00000000,B00000000,B00000000,B00000000,B11111110,B00000100,B00001000 };
byte z[8]={
B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B11111110,B00000100 };
byte f[8]={
B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B00000000,B11111110 };
/* now display them one by one with a small delay */
lc.setRow(0,0,w[0]);
lc.setRow(0,1,w[1]);
lc.setRow(0,2,w[2]);
lc.setRow(0,3,w[3]);
lc.setRow(0,4,w[4]);
lc.setRow(0,5,w[6]);
lc.setRow(0,6,w[7]);
lc.setRow(0,7,w[8]);
delay(delaytime);
lc.setRow(0,0,a[0]);
lc.setRow(0,1,a[1]);
lc.setRow(0,2,a[2]);
lc.setRow(0,3,a[3]);
lc.setRow(0,4,a[4]);
lc.setRow(0,5,a[5]);
lc.setRow(0,6,a[6]);
lc.setRow(0,7,a[7]);
delay(delaytime);
lc.setRow(0,0,q[0]);
lc.setRow(0,1,q[1]);
lc.setRow(0,2,q[2]);
lc.setRow(0,3,q[3]);
lc.setRow(0,4,q[4]);
lc.setRow(0,5,q[5]);
lc.setRow(0,6,q[6]);
lc.setRow(0,7,q[7]);
delay(delaytime);
lc.setRow(0,0,c[0]);
lc.setRow(0,1,c[1]);
lc.setRow(0,2,c[2]);
lc.setRow(0,3,c[3]);
lc.setRow(0,4,c[4]);
lc.setRow(0,5,c[5]);
lc.setRow(0,6,c[6]);
lc.setRow(0,7,c[7]);
delay(delaytime);
lc.setRow(0,0,s[0]);
lc.setRow(0,1,s[1]);
lc.setRow(0,2,s[2]);
lc.setRow(0,3,s[3]);
lc.setRow(0,4,s[4]);
lc.setRow(0,5,s[5]);
lc.setRow(0,6,s[6]);
lc.setRow(0,7,s[7]);
delay(delaytime);
lc.setRow(0,0,y[0]);
lc.setRow(0,1,y[1]);
lc.setRow(0,2,y[2]);
lc.setRow(0,3,y[3]);
lc.setRow(0,4,y[4]);
lc.setRow(0,5,y[5]);
lc.setRow(0,6,y[6]);
lc.setRow(0,7,y[7]);
delay(delaytime);
lc.setRow(0,0,z[0]);
lc.setRow(0,1,z[1]);
lc.setRow(0,2,z[2]);
lc.setRow(0,3,z[3]);
lc.setRow(0,4,z[4]);
lc.setRow(0,5,z[5]);
lc.setRow(0,6,z[6]);
lc.setRow(0,7,z[7]);
delay(delaytime);
lc.setRow(0,0,f[0]);
lc.setRow(0,1,f[1]);
lc.setRow(0,2,f[2]);
lc.setRow(0,3,f[3]);
lc.setRow(0,4,f[4]);
lc.setRow(0,5,f[5]);
lc.setRow(0,6,f[6]);
lc.setRow(0,7,f[7]);
delay(delaytime);
lc.setRow(0,0,0);
lc.setRow(0,1,0);
lc.setRow(0,2,0);
lc.setRow(0,3,0);
lc.setRow(0,4,0);
lc.setRow(0,5,0);
lc.setRow(0,6,0);
lc.setRow(0,7,0);
delay(delaytime);
writeWWWWWWWWOnMatrix();
delay(200);
delay(200);
delay(200);
sadhish
anyone pls help me..during compilation an error may occur 1."byte" does not name a type 2.byte has not been declared 3.boolean has not been declared...............am also impoted the arduino library.led control.h
AWOL
Make sure you've included "Arduino.h".
Please don't hijack threads.
"Pete, it's a fool looks for logic in the chambers of the human heart." Ulysses Everett McGill.
Do not send technical questions via personal messaging - they will be ignored.
I speak for myself, not Arduino.
