Topic: Need board/connector/cable for 20 pin 128x64 display for a Mega (Read 2060 times) previous topic - next topic
mjbmikeb
I haven't seen anything pre-made, and building it by hand is a pain because there are 20 wires, a pot for the contrast and a resistor for the backlight.
Even finding single row 20 pin ribbon cables is a challenge.
I just want an easy way of connecting to pin 22 onwards (avoiding the SPI pins) on the Mega. It doesn't have to be a full shield.
sixeyes
After a recommendation on this forum, I've been using the old 40 pin IDE cables (not the 80 way newer faster IDE cables).
At the Mega end I break them out into a 20 pin header and solder the wires to each pin. At least I've only got to do this on one end.
I also wire the upper / lower pins for each row together, that way it doesn't matter if I plug it in at the display using either row.
Iain
liudr
My solution might be worth looking at if you used UNO or 2009. You can connect everything to your breadboard and pass the connection to arduino.
http://liudr.wordpress.com/gadget/phi-connect/
I managed to run hard drive cable up to 18' long without signal problem so hard drive cable will definitely solve your problem.
AKSoapy29
Andrew K.
liudr
Yeah!
Add a pin to this arduino user map, will you?
http://maps.google.com/maps/ms?ie=UTF8&hl=en&msa=0&msid=203855014878637041865.00048bf511125d88d5fc7&ll=16.25757,-119.677334&spn=177.72321,272.109375&z=1
liudr
There are at least 3 versions of pin outs so the board would be almost the size of a shield :) I might try something soon. "GLCD instant gratification shield" ;)
