Loading...
Pages: [1]   Go Down
Author Topic: TLC5940 and 12V Power  (Read 1112 times)
Portland Oregon
Offline Offline
Newbie
Blink
View Profile
WWW
Hi All
Can anyone give me some tips on where to place the capacitors on the TLC5940 so that I can use a separate 12V power supply to power LEDs?
I got pulled into this by this lesson:
http://www.arduino.cc/playground/Learning/TLC5940
It works great with low power LEDs but no luck powering LEDs that require 12V.
I have read that I need to get rid of the IREF 2.2 resistor and that makes sense to me because the higher voltage I am trying to use.
I then read that I should use a 10uF Cap to filter the LED Power supply. At least one is required, two are preferred.  Should these go between the 12V source and the ground?  I am powering the TLC with 3.3 from the Arduino and the LEDs from a 12V.  Should I ground the 12V supply to the arduino?
And then I think I need a 1.0uF Caps to decouple the power supply.  Do I connect this between pin 20 and the ground?
I don't think I will need any resistors at all for the TLC5940.  The LEDs have their own resistors already built into the strips.
Any tips on where the capacitors go would be really helpful.
Thanks,
Fred
Logged
It would probably be safer to play with matches.
http://www.unhingedfx.com
http://www.fredknack.com
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
For a start decoupling is needed, between +5 and ground and between 12V and ground.
http://www.thebox.myzen.co.uk/Tutorial/De-coupling.html
The TLC5940 can operate with a 12V supply to the chip. In fact it will operate up to 17V.
However:-
Quote
Yes you need a current setting resistor.
Quote
If you don't nothing will work.
http://www.thebox.myzen.co.uk/Tutorial/Power_Supplies.html
Quote
Makes absolutely no sense to me.
Quote
That suggests they might not be suitable for driving with the TLC5940 - how much current do they take?
Logged
Portland Oregon
Offline Offline
Newbie
Blink
View Profile
WWW
Thanks Mike!
I will go through your links and tips and see if I can make any headway.
I am trying to base my project on this Brilldea design:
http://www.brilldea.com/product_LEDPainter.html
I am trying to do the same thing but with my own breadboard, ICs, capacitors and resistors.
The LEDs I have are these:
http://www.brilldea.com/product_RGBRibbon.html
I will post again when I have made some progress.
Fred
Logged
Offline Offline
Newbie
View Profile
Hi Fred,
I am currently looking into doing a similar project with the 12V strip lights.
Obviously the Brilldea project uses TLC5940 as a driver for the the strips so it's really a question of implementation.  It appears they have an instruction page, probably a parts list, etc,  have you tried using that as a baseline? What is going wrong with your design... you just said  it doesn't work, what doesn't work... do you have any troubleshoot tools like a DMM to figure out what is going wrong with your circuit? If not you should get a multimeter at the very least.
One thing to note that their individual strips are a bit of a ripoff if you want a large quantity of them.  You can buy a large 5meter reel off ebay for much cheaper ($30-40 for 50 strips)
Logged
Portland Oregon
Offline Offline
Newbie
Blink
View Profile
WWW
Thanks for your reply Steve.
I got it working!
http://youtu.be/xoxdGcm2wik
I did try to use the Brilldea design as a baseline.  That is where I got the idea that I needed some capacitors but I was not sure where to put them.  My total lack of understanding was absolutely no help  smiley-fat
I did get the lights working though.  I read Grumpy Mike’s page about De-Coupling and tried to implement that the best I could but in the end my problem was something else I learned from Mike’s power supply page that really fixed the problem.  I simply needed to have the 12V supply and the 5V supply share a ground.  That fixed it.
I am still confused about the capacitors because it works with or without them.  But my understanding from Mike’s page is that they will help the overall consistency of the design.
Thanks for your advice about the ebay deals.  I think you are right.  All Brilldea sent me was a long string of lights that I had to cut up to add (hack) connectors to.  I am sure the ebay products are similar.  I can say that I am a HUGE fan of this kind of LED.  They are really bright.  I was trying to create my project with an RGB LED matrix and that was way to much work for the minimal light intensity.
Now my next power related problem is that I want to create both a 12V and 5.5V regulated power supply from one cord.  I need to split the power to supply both the low voltage boarduino and the 12V leds.  I think I ‘understand’ the voltage regulator circuits necessary but I am not sure if I need to use a 24V supply and then break up into 12V and 5.5V supplies or if the single 12V supply can handle both power supply circuits.  I know that this must really expose my lack of basic understanding but I am simply fishing for clues so I know what to search for. Any ideas?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Use a 12V power supply, for your LEDs and then use that same supply to regulate another line down to 5V.
Logged
Portland Oregon
Offline Offline
Newbie
Blink
View Profile
WWW
Thanks for the quick answer Grumpy!  I was hoping that was the case.  I am now off to build my first power supply circuit.  Be very very smiley-eek-blue
Logged
Pages: [1]   Go Up
Print
Jump to:
