Topic: LM 34/35 temperature sensor+relay (Read 1 time) previous topic - next topic
raj@arduino
Hi i have tried the following :
Code: [Select]
An open-source LM35DZ Temperature Sensor for Arduino. This project will be enhanced on a regular basis
(cc) by Daniel Spillere Andrade , http://www.danielandrade.net
http://creativecommons.org/license/cc-gpl
int pin = 0; // analog pin
int tempc = 0,tempf=0; // temperature variables
int samples[8]; // variables to make a better precision
int maxi = -100,mini = 100; // to start max/min temperature
int i;
  Serial.begin(9600); // start serial communication
for(i = 0;i< =7;i++){ // gets 8 samples of temperature
  samples[i] = ( 5.0 * analogRead(pin) * 100.0) / 1024.0;
  tempc = tempc + samples[i];
tempc = tempc/8.0; // better precision
tempf = (tempc * 9)/ 5 + 32; // converts to fahrenheit
if(tempc > maxi) {maxi = tempc;} // set max temperature
if(tempc < mini) {mini = tempc;} // set min temperature
Serial.print(tempc,DEC);
Serial.print(" Celsius, ");
Serial.print(tempf,DEC);
Serial.print(" fahrenheit -> ");
Serial.print(maxi,DEC);
Serial.print(" Max, ");
Serial.print(mini,DEC);
Serial.println(" Min");
tempc = 0;
Done successfully ,,
The thing is i want to extend the same for the following requirements:
1.  there is a  heating element ,a resistor which is heated up by a dc source of 5v,, Lm 34/35 senses the temp and continuously reads .. and displays
2.we have a set temperature and if it exceeds the relay cuts the dc supply.
Any one plz help me on this
PaulS
What kind of relay are you using? How is it connected to the Arduino? Does it control the heater?
Generally, turning a relay on is as simple as:
Code: [Select]
digitalWrite(relayPin, HIGH);
and turning it off is as simple as:
Code: [Select]
digitalWrite(relayPin, LOW);
Turning the relay on and off at the right temperature is done using an if statement.
robtillaart
you need to do the if statement carefully and use two different temperatures to switch. These can be based upon one setTemp by means of two offsets.
Code: [Select]
if (tempc > setTemp+1) digitalWrite(pin, LOW);
if (tempc < setTemp-1) digitalWrite(pin, HIGH);
this prevents that when the temperature is around setTemp that the relay is "buzzing" on and off constantly. You can define the behaviour by changing the offsets +1 and -1 e.g to +0 and -4
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
