Topic: 595 & 4021 multiplexing (Read 3982 times) previous topic - next topic
Frenk
Isn`t 74LS595 shift out chip?
I tried a different protoboard, but I get the same results. I tried to use pull ups, but I think I can`t write the program to work correctly. Also I didn`t find time to work on my project, hope I will made it till than. I don`t know why the interference would be a problem with a wires only two or three centimeters long(from buttons to chip) and bit more from chip to arduino board? Maybe the material the wire is made is guilty?
I also tried to connect only one button on chip, and when I push it, I get all eight logic "1" on serial monitor.
Grumpy_Mike
Quote
Yes it is, are you using it as an input? It is the 4021 that is the input chip. Have you got a link to how you have wired it up.
That length of wire is fine.
Quote
That sounds to me like you haven't wired things up right.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
