Topic: LCD_screen Library Suite (Read 62135 times) previous topic - next topic
Docedison
Then all that is available is the 023 code released in may 2012?
Doc
--> WA7EMS <--
avenue33
The release published in May comes in two flavours:
  • Arduino 23 in the branch master available at https://github.com/rei-vilo/Serial_LCD
  • Arduino 1.0 in the branch Arduino-1.0 available at https://github.com/rei-vilo/Serial_LCD/tree/Arduino-1.0
The next release is going to combine both of them (Arduino 23 + 1.0) but does not include any additional feature.
avenue33
#137
Jul 12, 2012, 05:53 pm Last Edit: Jul 13, 2012, 10:09 am by avenue33 Reason: 1
Please find the new release of the Serial_LCD library suite, with
Jul 12, 2012 release 132
• Unified release: one single library for Arduino 23 and 1.0, chipKIT MIPDE and Wiring
• Optimised code: lighter memory footprint
• New graphic: multiple histogram with up to 4 series of values
As always, find documentation, tutorials, examples, code and downloads at http://embeddedcomputing.weebly.com/serial-lcd
Documentation on a PDF file is planned to be released later on.
avenue33
After many hours of hard work, the documentation for the Serial_LCD Library Suite is available!
It comes in three different flavours:
• PDF file with index, ~0.6MB
• Document set docset bundle for Xcode, ~2.9MB
• HTML files folder with search script, ~5.5MB
Download from here
avenue33
#139
Jul 30, 2012, 01:27 pm Last Edit: Aug 01, 2012, 01:50 am by avenue33 Reason: 1
Jul 300, 2012 • Version 3
Version 3 merges versions 1 and 2 into a single unified release. It supports Arduino 23, Arduino 1.0, chipKIT MPIDE and Wiring.
Previous version 1 supported Arduino 23 and chipKIT MPIDE, while version 2 was specific to Arduino 1.0, in parallel with version 1.
As always, find documentation here and download from there.
Graynomad
I think there's a typo on your download page, one button has "doscet" as the label.
_____
Rob
Graynomad
#141
Jul 30, 2012, 05:22 pm Last Edit: Jul 30, 2012, 05:25 pm by Graynomad Reason: 1
But what does doscet mean :), have a good look at the buttons.
______
Rob
avenue33
Hi!
Thanks to an extensive feed-back from Docedison, I posted a revised set of examples.
Get them from the GitHub repository.
Thank you Docedison :)
Docedison
Although pricey compared to a 3.2" TFT01 3.2WD and the UTFT lib's it is a really nice work horse 1 16 bit, or an 8 bit W/Flow control or2 8 bit ports or a 16 bit individual port all are bi-directional, 2 TTL RS232 serial Ports and a speaker. The device can communicate at up to 2.56 Mbaud comm rates on a dedicated TTL RS232 port and change that data rate on the fly so as to not get in the way of touch screen data and it's interactions the 32PT SGC device can do a lot... With a change in it's firmware it can be programmed to operate as a standalone terminal GFX mode and the program and stored data is easily accommodated by it's high capacity uSD card port 4GB + ... All for $69.00  from 4D Systems.AU... (79.00 @ Robot Shop and $84.00 @ Sparkfun) I bought one and the Backplane connector ($20 -30.00) for easy access to the additional I/O. Although a resistive touch screen the device I have is very responsive with the protective plastic still in place. In short it is a lot of display and while you can easily (now as the prices have fallen) buy 2 3.2 " displays for the same money you'll not find one that can do what it does 'naturally'. Maybe a Pro-Mini and a TFT01 and... but Not all in one with the SD card capacity this one has... The graphics are fast, clean and really good looking.
As much as this might sound an advert for 4D Systems... It isn't, The 32PT SGC IS a LOT of DISPLAY.
Doc
--> WA7EMS <--
avenue33
A new release of the Serial_LCD library suite is available, with support for the AVR ATmega1280 MCU.
Aug 21, 2012 release 334 • __AVR_ATmega1280__ added
Deprecation notice
Please note that button.define, button.stringDefine and Label are going to be deprecated in the next major release.
Consider button.dDefine, button.dStringDefine and dLabel instead.
The examples have been updated accordingly.
As always, everything is available here.
luttoa
Great Work Avenue 33
My 4D display should be arriving in a few days and I cant wait to play with the functionality provided.
God knows the hours that must have gone into this.
Thanks
Andy
avenue33
@Andy
Thank you for the accolade!
As for the time, ~450 hours and counting!
avenue33
Please find a new release of the Serial_LCD Library Suite:
Sep 01, 2012 release 335 • __AVR_ATmega32U4__ added
The Arduino Leonardo is now supported.
Performance enhancements have also been added.
Please note that button::define, button::stringDefine and Label are going to be deprecated in the next major release.
Consider button::dDefine, button::dStringDefine and dLabel instead.
As always, documentation and download are available here.
Enjoy ;)
avenue33
Sep 19, 2012 release 336 • stability enhancement
especially for the Gallery library.
A very tricky bug with chipKIT has been fixed. Actually, chipKIT MPIDE doesn't support vector --see http://www.chipkit.org/forum/viewtopic.php?f=6&t=1511&hilit=vector
As always, documentation is here and download there!
Enjoy ;)
