Loading...
Pages: [1]   Go Down
Author Topic: WiFly Webserver Problems - Help needed  (Read 818 times)
Offline Offline
Newbie
View Profile
Hello!
First i have to say the Arduino platform is very interesting, i stumbled on it accidentally.
Unfortunately I am not an experienced programmer and now i have i problem with my project....
I use an Arduino UNO and a Sparkfun WiFly-Shield (http://www.watterott.com/de/SparkFun-WiFly-Shield) with the Alpha 2 Release of the Experimental WiFly Arduino Library from Sparkfun.
I only need to switch one relay and measure the temperature. Right now eveything works, but not reliable!
My problems:
1.
After i power on the Arduino, i need to press reset switch once bevore the WiFly-Shield connects to my WLAN. Why?
Do i need to add some reset functions to my code?
2.
If i try to connect via web, it is not responding reliable. Sometimes it is not responding at all (and i have to press reset, maybe a loop?), pinging the WiFly-Shield is without problems at all. Ping works always. So i think my programming is not correct.
Here is the code based on some examples:
Code:
#include "WiFly.h"
#include "WString.h"
boolean LEDON = false;
String readString;
const int ledPin =  9; //digital pin for magnet
int pin = 5; // analog pin for temperature
int tempc = 0,tempf=0; // temperature variables
int samples[8]; // variables to make a better precision
int maxi = -100,mini = 100; // to start max/min temperature
int i;
Server server(80);
  server.begin();
  SpiSerial.begin();
  //exit CMD mode if not already done
  SpiSerial.println("");
  SpiSerial.println("exit");
  //set into CMD mode
  SpiSerial.print("$$$");
  //set authorization level
  SpiSerial.println("set w a 4");
  //set passphrase
  SpiSerial.println("set w p MYPASSPHRASE");
  //set different stuff to be shure
  SpiSerial.println("set ip dhcp 0");
  SpiSerial.println("set ip address 192.168.0.222");
  SpiSerial.println("set ip gateway 192.168.0.1");
  SpiSerial.println("set ip netmask 255.255.255.0");
  //set localport
  SpiSerial.println("set i l 80");
  //disable *HELLO* default message on connect
  SpiSerial.println("set comm remote 0");
  //join wifi network <ssid>
  SpiSerial.println("join MYSID");
  delay(5000);
  //exit CMD mode
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  LEDON = false;
  //digitalWrite(ledPin, HIGH);
  // listen for incoming clients
  Client client = server.available();
  if (client) {
    //start Temperatur sensing
    for(i=0; i<=7; i++){ // gets 8 samples of temperature
      samples[i] = ( 5.0 * analogRead(pin) * 100.0) / 1024.0;
      tempc = tempc + samples[i];
    // an http request ends with a blank line
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        if (readString.length() < 100)
          //store characters to string
          readString += c; //replaces readString.append(c);
        if (c == '\n') {
          //if (c == '\n' && currentLineIsBlank) {
          if(readString.indexOf("gate=0")>-1){
            //led has to be turned OFF
            digitalWrite(ledPin, LOW);    // set the LED OFF
            LEDON = false;
          } ///else
          if(readString.indexOf("gate=1")>-1) {
            //led has to be turned ON
            digitalWrite(ledPin, HIGH);    // set on (5 Volts)
            delay(5000);
            digitalWrite(ledPin, LOW);    // set off
            //LEDON = true;
          tempc = tempc/8.0; // better precision
          tempf = (tempc * 9)/ 5 + 32; // converts to fahrenheit
          if(tempc > maxi) {
            maxi = tempc;
          } // set max temperature
          if(tempc < mini) {
            mini = tempc;
          } // set min temperature
          client.println("Content-Type: text/html");
          client.println();
          // print something, in HTML format:
          client.println("<h3><a href=\"http://192.168.0.222?gate=1\">Open Relay for 5 seconds</a></h3>");
          client.println("<br />");
          client.println("<h4>Temperature: ");
          client.println(tempc);
          client.println(" Grad Celsius</h4>");
        if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    //clearing string for next read
    readString="";
    tempc = 0;
    // give the web browser time to receive the data
    delay(100);
    // close the connection:
    client.stop();
Regards
J.Fester
Logged
Pages: [1]   Go Up
Print
Jump to:
