Loading...
Pages: [1]   Go Down
Author Topic: Lots of scope errors.  (Read 323 times)
Offline Offline
Newbie
View Profile
Hey everyone.
I've been working on a trip computer MPG calculator kind of thing inspired by the opengauge/MPGuino. The leader of that project moved away from the Arduino environment (and yet keeps the *uino name? :p ), so I decided to create my own version from scratch. It was working great up until an hour or so ago when I was tinkering with the code, adding comments, renaming variables and such... cleaning up before pushing forward.
I tried compiling the code (via the verify button) to figure out where I had missed a variable replacement or ten (the Arduino app REALLY needs a find/replace function... hint hint), but the compiler started throwing all kinds of scope errors, some of them completely ridiculous:
Code:
MPGshield:138: error: 'digitalRead' was not declared in this scope
MPGshield:138: error: 'LOW' was not declared in this scope
MPGshield:140: error: 'micros' was not declared in this scope
umm... 'lil help?  smiley-confuse
Logged
Left Coast, USA
Offline Offline
Sr. Member
Sometimes I just can't help myself.
View Profile
Hey everyone.
Everyone says hey!
Quote from: bobski
...I was...adding comments...the compiler started throwing all kinds ...
The major head-scratcher is the fact that the multi-line comment starting after the #define directive on line 26 is too long.  (Yes, believe it or not, sometimes comments can kill you!  Really.)
To fix it you can just put the #define on a separate line like this:
Code:
  how many microseconds of discontinuity between the injector electrical signal and actual fuel flow time.
  this number gets subtracted from the measured length of each injector firing event. if your injector closes
  faster than it opens, the fuel flow time will be shorter than the electrical pulse, and injectorFiringDelay
  should be positive. if the injector opens faster than it opens, this value should be negative.
#define injectorFiringDelay 0
Or...
Just change the original lines 26-29 to something like
Code:
#define injectorFiringDelay 0      //how many microseconds of discontinuity between the injector electrical signal and actual fuel flow time.
                                   //  this number gets subtracted from the measured length of each injector firing event. if your injector closes
                                   //  faster than it opens, the fuel flow time will be shorter than the electrical pulse, and injectorFiringDelay
                                   //  should be positive. if the injector opens faster than it opens, this value should be negative.
Then you will get a few actually meaningful error messages that you can, undoubtedly, get to the bottom of so that it will be ready for testing/debugging.
Regards,
Dave
Footnote:
Whew!
« Last Edit: May 10, 2011, 11:58:24 pm by davekw7x » Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Ctrl+F gets you find and replace.
Logged
Offline Offline
Newbie
View Profile
Huh... That's bizarre. Thanks though - that knocked me down to one replacement I had missed.
So it does! It's even in the menus... I must be blind. >_<
Logged
Pages: [1]   Go Up
Print
Jump to:
