Loading...
Pages: [1]   Go Down
Author Topic: Measuring Vertical Linear Movement  (Read 574 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Hey,
Here's the riddle that needs to be solved: how to measure vertical linear movement?
Four sensors with a travel range of 10cm are needed.
Two sensors with a range double of this, so around 20cm.
Right now I'm using a combination of four bend sensors
http://www.sparkfun.com/products/8606
-> They have the "feel" that we need - constant, small weight.
-> They are not very stable, robust or precise.
And one of these - a drawstring linear displacement sensor
http://www.pennyandgiles.com/Draw-Wire-Linear-Sensors-pd-61,3,,.php
-> Very stable and precise, long range.
-> The "feel" is not quite right. Because of the spring in this sensor, it feels "heavy" when pulled.
So, my idea was "super smooth linear faders" with weights,
but these turn out very hard to find especially in lengths > 10cm.
Do any of you guys have any ideas for other sensors or setups to reach this goal?
So far.
All suggestions very much appreciated,
Jim
« Last Edit: May 11, 2011, 11:23:43 am by Blue_Boy » Logged
Central MN, USA
Offline Offline
Faraday Member
Phi_prompt, phi_interfaces, phi-2 shields, phi-panels
View Profile
WWW
Can you share your setup picture with us? No idea what to recommend. Maybe IR sensors or sonic ranger.
Logged
Global Moderator
Boston area, metrowest
Offline Offline
Brattain Member
Available for Design & Build services
View Profile
WWW
How about attaching a paper tab with horizontal strips that goes up & down with whatever you have, then a sensor at the base that senses the stripes going past and reports that a count or something similar?
Logged
Designing & building electrical circuits for over 25 years. Check out the ATMega1284P based Bobuino and other '328P & '1284P creations & offerings at  www.crossroadsfencing.com/BobuinoRev17
Silly-con Valley, Ca, U.S.
Offline Offline
Sr. Member
Lernin' to tinker
View Profile
WWW
I was thinking liner encoder using IR as well.
Logged
10 PRINT CHR$(7)
20 GOTO 10
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Here's a picture of the current setup.
I would prefer absolute readings over encoder systems.
http://www.jimboproductions.be/server/mda/gamehub/PuppetMaster_Photo/DSC_4262.jpg
Logged
Global Moderator
Offline Offline
Brattain Member
View Profile
WWW
Got a picture of it when it has moved some?
Logged
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Nope, sorry.
In fact, in this picture, one out of five sensors has moved already.
The drawstring out of the drawstring sensor has already been extended.
If the "playing cross" is moved higher, the ends of the flex sensors will be pulled upwards,
and bend as a result.
Logged
Pages: [1]   Go Up
Print
Jump to:
