Topic: Measuring Vertical Linear Movement (Read 2305 times) previous topic - next topic
Blue_Boy
May 11, 2011, 05:31 pm Last Edit: May 11, 2011, 06:23 pm by Blue_Boy Reason: 1
Hey,
Here's the riddle that needs to be solved: how to measure vertical linear movement?
Four sensors with a travel range of 10cm are needed.
Two sensors with a range double of this, so around 20cm.
Right now I'm using a combination of four bend sensors
http://www.sparkfun.com/products/8606
-> They have the "feel" that we need - constant, small weight.
-> They are not very stable, robust or precise.
And one of these - a drawstring linear displacement sensor
http://www.pennyandgiles.com/Draw-Wire-Linear-Sensors-pd-61,3,,.php
-> Very stable and precise, long range.
-> The "feel" is not quite right. Because of the spring in this sensor, it feels "heavy" when pulled.
So, my idea was "super smooth linear faders" with weights,
but these turn out very hard to find especially in lengths > 10cm.
Do any of you guys have any ideas for other sensors or setups to reach this goal?
So far.
All suggestions very much appreciated,
Jim
liudr
Can you share your setup picture with us? No idea what to recommend. Maybe IR sensors or sonic ranger.
CrossRoads
How about attaching a paper tab with horizontal strips that goes up & down with whatever you have, then a sensor at the base that senses the stripes going past and reports that a count or something similar?
biocow
I was thinking liner encoder using IR as well.
10 PRINT CHR$(7)
20 GOTO 10
Blue_Boy
Here's a picture of the current setup.
I would prefer absolute readings over encoder systems.
http://www.jimboproductions.be/server/mda/gamehub/PuppetMaster_Photo/DSC_4262.jpg
CrossRoads
Got a picture of it when it has moved some?
Blue_Boy
Nope, sorry.
In fact, in this picture, one out of five sensors has moved already.
The drawstring out of the drawstring sensor has already been extended.
If the "playing cross" is moved higher, the ends of the flex sensors will be pulled upwards,
and bend as a result.
