Topic: Micro printer cbm1000 circuit problems (Read 1 time) previous topic - next topic
maxdovey
Im trying to get my arduino talking to a CBM1000 receipt printer for my final project.
Ive found some really helpful hacker resources and a guide here http://microprinter.pbworks.com/w/page/21489360/CBM-1000
i also followed this tutorial http://www.aggsoft.com/rs232-pinout-cable/serial-cable-connections.htm
except im using 1uF capacitors and a Max232 chip.
Ive changed the serial port so they collate from a 9 pin to a 25 pin. ( 1=8 , 6=6, 4 = 20 , 7 = 4 , 8 =5)
and then i sent roo reynolds sketch https://github.com/rooreynolds/microprinter.git although the receive light flashes it does not transmit.
can anyone help me with this?
Coding Badly
Is the printer broken?  Have you tested it with a PC (or something that is not an Arduino)?
maxdovey
Hi, the printer runs successful test prints but the arduino does not Transmit (TX) only RX from the sample sketches.
thanks
anachrocomputer
Did you swap 3 and 2? They're the other way round on a 9-pin from a 25-pin. Also, 9-pin ground is 5, 25-pin ground is 7.
