Chester, UK
« on: May 12, 2011, 02:11:09 pm » |
Hi Guys,
Got a little issue, & feel a little silly!
I have been lurking here for a while, I am also new to arduino, so sorry for the silly questions etc..(case of little knowlage == Dangerous)
I am working on a little battery/solar powerd rfid logging project for orienteering etc. This consists of an Seeeduino Stalker V2, RFID Reader, Battery and Solar Panel in a Waterproof encloser.
I have wrote (well cobbled together using bits and bobs of code from around the net) a sketch that would read an rfid tag, validate the cheksum if valid then write the tags serial number and the time it is swiped to the sd card. I plan in the future adding the temp also as the temp sensor is built in to the stalker.
I uploaded the sketch to my Stalker V2, then I had the shock of my life! It worked!!!
After about half an hour of jumping up and down and also a beer to celebrate, I realised that I needed to set the time!!! Talk about pride before a fall!!
How do you set the RX8025 RTC on the Stalker V2?
I have the code in my sketch I enter the value in this code for the time I want to set, I upload that to the stalker, then comment out the two lines that were used to set the time and then re-upload my code as I do not want it reseting the time everytime the stalker powers up, as is my understanding.
I just can't set the dam time, Can any one help?
I have the code in my sketch to set the time but can't get the little fella to work.
Code Below => Due to post limit
This cannot be as hard as I am making it?
Chester, UK
« Reply #1 on: May 12, 2011, 02:11:36 pm » |
/* SD card datalogger (RFID swipe-time logger) Log data from UART RFID reader to an SD card using the SD library. */
#include <RX8025.h> #include <Wire.h> #include <SD.h> #include <NewSoftSerial.h>
//Define the value of rfid start bit #define stx 2
//Define the value of rfid end bit #define etx 3
// On the Ethernet Shield, CS is pin 4. Note that even if it's not // used as the CS pin, the hardware CS pin (10 on most Arduino boards, // 53 on the Mega) must be left as an output or the SD library // functions will not work. const int chipSelect = 10;
//Dont forget to change the values in 'NewSoftSerial' below if you move the rfid rx and tx pins somewhere else NewSoftSerial mySerial(2, 3); int counter; byte data[14]; byte hexBlock1,hexBlock2,hexBlock3,hexBlock4,hexBlock5; byte hexCalculatedChecksum,hexChecksum;
void setup() { pinMode(8,OUTPUT);//LED pin set to OUTPUT Serial.begin(9600); mySerial.begin(9600);
//To set the clock - uncomment two lines below unsigned char RX8025_time[7]={0x00,0x35,0x00,0x00,0x11,0x05,0x11};//second, minute, hour, week, date, month, year, BCD format RX8025.setRtcTime(RX8025_time);
//RTC RX8025.init();
//Announce the script Serial.println("RFID Logger V1.02");
//initializ sd card Serial.println("Initializing SD Card...");
// make sure that the default chip select pin is set to // output, even if you don't use it: pinMode(10, OUTPUT);
// see if the card is present and can be initialized: if (!SD.begin(chipSelect)) { Serial.println("SD Card failed, or not present"); // don't do anything more: return; } Serial.println("SD Card initialized."); }
void loop() { digitalWrite(8,LOW);//LED pin set to OUTPUT //read the rfid tag if present if (mySerial.available() > 0) { data[counter] = mySerial.read(); counter++; if(counter > 13) { //we read the whole message, so reset counter counter = 0; //check if start of text and end of text is correct if(data[0] == stx && data[13] == etx) { digitalWrite(8,HIGH);//LED pin set to OUTPUT Serial.println("Start of text and end of Tag St correctly received."); Serial.print("ID: "); //show ID for(int x = 1; x < 11; x++) { Serial.print(data[x], BYTE); }
Serial.println(""); Serial.print("Checksum: "); //show checksum Serial.print(data[11], BYTE); Serial.println(data[12], BYTE);
//Hex ID blocks. Two transmitted Bytes form one Hex ID block. //Hex ID blocks: 6 2 | E 3 | 0 8 | 6 C | E D //Transmitted Bytes: 36H 32H | 45H 33H | 30H 38H | 36H 43H | 45H 44H
hexBlock1 = AsciiCharToNum(data[1])*16 + AsciiCharToNum(data[2]); hexBlock2 = AsciiCharToNum(data[3])*16 + AsciiCharToNum(data[4]); hexBlock3 = AsciiCharToNum(data[5])*16 + AsciiCharToNum(data[6]); hexBlock4 = AsciiCharToNum(data[7])*16 + AsciiCharToNum(data[8]); hexBlock5 = AsciiCharToNum(data[9])*16 + AsciiCharToNum(data[10]);
//Transmitted checksum. hexChecksum = AsciiCharToNum(data[11])*16 + AsciiCharToNum(data[12]);
//XOR algorithm to calculate checksum of ID blocks. hexCalculatedChecksum = hexBlock1 ^ hexBlock2 ^ hexBlock3 ^ hexBlock4 ^ hexBlock5; if ( hexCalculatedChecksum == hexChecksum ) { Serial.println("Calculated checksum matched transmitted checksum.");
//going to write it all to sd now Serial.println("Will try to write ID and checksum to datalog.txt on SD now.");
// open datalog.txt. note that only one file can be open at a time, // so you have to close this one before opening another. File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it: if (dataFile) { //Write the RFID Card ID //***************I am sure I need to convert to ascii befor printing? is the byte already ascii? //***************but will see if this works for now think will print hex?, same with the output to the serial monitor dataFile.print("Card ID: "); dataFile.print(data[1], BYTE); dataFile.print(data[2], BYTE); dataFile.print(data[3], BYTE); dataFile.print(data[4], BYTE); dataFile.print(data[5], BYTE); dataFile.print(data[6], BYTE); dataFile.print(data[7], BYTE); dataFile.print(data[8], BYTE); dataFile.print(data[9], BYTE); dataFile.print(data[10], BYTE); dataFile.print(", ");
//write RFID cards checksum dataFile.print("Checksum: "); dataFile.print(data[11], BYTE); dataFile.print(data[12], BYTE); dataFile.print(", ");
//Log the time from the rtc int rtc_sec, rtc_min, rtc_hou, rtc_wee, rtc_dat, rtc_mon, rtc_yea; delay(300); // There will be new values every 100ms
RX8025.getRtcTime(&rtc_sec, &rtc_min, &rtc_hou, &rtc_wee, &rtc_dat, &rtc_mon, &rtc_yea);
dataFile.print(rtc_dat,DEC); dataFile.print("/"); dataFile.print(rtc_mon,DEC); dataFile.print("/"); dataFile.print(rtc_yea,DEC); dataFile.print(" "); dataFile.print(rtc_wee,DEC); dataFile.print(" "); dataFile.print(rtc_hou,DEC); dataFile.print(":"); dataFile.print(rtc_min,DEC); dataFile.print(":"); dataFile.println(rtc_sec,DEC);
//close the sd file? dataFile.close();
// print to the serial port for monitoring monitorout();
//turn led off digitalWrite(8,HIGH);//LED pin set to OUTPUT
mySerial.flush();
delay(1000); }
// if the file isn't open, pop up an error: else { Serial.println("Error opening data file - datalog.txt");
return; } }
else { Serial.println("Calculated checksum didn't match transmitted checksum. Corrupt data!"); Serial.println("Please scan again"); // don't do anything more: return; }
uint8_t AsciiCharToNum(byte data) {
//First substract 48 to convert the char representation //of a number to an actual number. data -= '0';
//If it is greater than 9, we have a Hex character A-F. //Substract 7 to get the numeral representation. if (data > 9) data -= 7; return data; } void rfiddata() {
void monitorout(){ Serial.print("Card Sc "); Serial.print("Card ID: "); Serial.print(data[1], BYTE); Serial.print(data[2], BYTE); Serial.print(data[3], BYTE); Serial.print(data[4], BYTE); Serial.print(data[5], BYTE); Serial.print(data[6], BYTE); Serial.print(data[7], BYTE); Serial.print(data[8], BYTE); Serial.print(data[9], BYTE); Serial.print(data[10], BYTE); Serial.print(", ");
//print cards checksum Serial.print("Checksum: "); Serial.print(data[11], BYTE); Serial.print(data[12], BYTE); Serial.print(", "); // print time
int rtc_sec, rtc_min, rtc_hou, rtc_wee, rtc_dat, rtc_mon, rtc_yea; delay(1000); // There will be new values every 100ms
Serial.print("Time:"); Serial.print(rtc_dat,DEC); Serial.print("/"); Serial.print(rtc_mon,DEC); Serial.print("/"); Serial.print(rtc_yea,DEC); Serial.print(" "); Serial.print(rtc_wee,DEC); Serial.print(" "); Serial.print(rtc_hou,DEC); Serial.print(":"); Serial.print(rtc_min,DEC); Serial.print(":"); Serial.println(rtc_sec,DEC); Serial.println("Done!"); Serial.println(" "); }
New Jersey
« Reply #2 on: May 13, 2011, 11:42:38 am » |
Guessing, but shouldn't the RX8025.init() come before you try to set the time?
Chester, UK
« Reply #3 on: May 17, 2011, 04:09:07 pm » |
Doh! That's exactly it silly me thank you.
« Reply #4 on: July 26, 2011, 03:54:49 pm » |
I have a problem with figuring out the RTC of a newly acquired stalker v2.0. I have played around with code such as found on this site or in this thread (nasukaren's post of 06.08.2010 at 12:55:33) or as in the TimeRTCSet example in the Time library. The problem is, I can set the RTC to a specified time but this time resets when I reset the board. In the case of the Time library example, I can send an ASCII time string over Serial (character 'T' followed by ten digits) to set time to whatever I want but it still resets when I reset the board (to midnight December 31st 1999). All of these examples use Time.h and DS1307RTC.h (and of course, Wire.h). Could it be that DS1307RTC.h cannot set the Stalker's RTC and I have to use RX8025.h instead? If I understand things correctly, RX8025.h does not use time_t which can be used by Time.h. If I got this right, I find it awkward (the Time library offers functionality I 'd rather not have to do without). Am I making some stupid mistake?
Seattle, WA USA
Seattle, WA USA
« Reply #5 on: July 26, 2011, 05:28:16 pm » |
Am I making some stupid mistake? I don't know that I would consider it "stupid", but, you didn't post any code.
« Reply #6 on: July 26, 2011, 06:04:54 pm » |
I don't want to clutter the thread with duplicate code since the two links in my original post both lead to code and the TimeRTCSet example is part of the Time library. Here it is: /* * TimeRTCSet.pde * example code illustrating Time library with Real Time Clock. * * RTC clock is set in response to serial port time message * A Processing example sketch to set the time is inclided in the download */
#include <Time.h> #include <Wire.h> #include <DS1307RTC.h> // a basic DS1307 library that returns time as a time_t
void setup() { Serial.begin(9600); setSyncProvider(RTC.get); // the function to get the time from the RTC if(timeStatus()!= timeSet) Serial.println("Unable to sync with the RTC"); else Serial.println("RTC has set the system time"); }
void loop() { if(Serial.available()) { time_t t = processSyncMessage(); if(t >0) { RTC.set(t); // set the RTC and the system time to the received value setTime(t); } } digitalClockDisplay(); delay(1000); }
void digitalClockDisplay(){ // digital clock display of the time Serial.print(hour()); printDigits(minute()); printDigits(second()); Serial.print(" "); Serial.print(day()); Serial.print(" "); Serial.print(month()); Serial.print(" "); Serial.print(year()); Serial.println(); }
void printDigits(int digits){ // utility function for digital clock display: prints preceding colon and leading 0 Serial.print(":"); if(digits < 10) Serial.print('0'); Serial.print(digits); }
/* code to process time sync messages from the serial port */ #define TIME_MSG_LEN 11 // time sync to PC is HEADER followed by unix time_t as ten ascii digits #define TIME_HEADER 'T' // Header tag for serial time sync message
time_t processSyncMessage() { // return the time if a valid sync message is received on the serial port. while(Serial.available() >= TIME_MSG_LEN ){ // time message consists of a header and ten ascii digits char c = Serial.read() ; Serial.print(c); if( c == TIME_HEADER ) { time_t pctime = 0; for(int i=0; i < TIME_MSG_LEN -1; i++){ c = Serial.read(); if( c >= '0' && c <= '9'){ pctime = (10 * pctime) + (c - '0') ; // convert digits to a number } } return pctime; } } return 0; }
I can send an ASCII string to set the time to whatever I want over the serial terminal but resetting the board resets the RTC. Example output: RTC has set the system time 0:00:00 31 12 1999 0:00:01 31 12 1999 0:00:02 31 12 1999 0:00:03 31 12 1999 0:00:04 31 12 1999 T23:31:31 13 2 2009 <--- Sent string T1234567890 23:31:32 13 2 2009 23:31:33 13 2 2009 23:31:34 13 2 2009 23:31:35 13 2 2009 RTC has set the system time <--- Reset button pressed 0:00:00 31 12 1999 0:00:01 31 12 1999 0:00:02 31 12 1999
Seattle, WA USA
Seattle, WA USA
« Reply #7 on: July 26, 2011, 07:26:30 pm » |
It looks to me like your RTC's battery is dead. Is it replaceable?
« Reply #8 on: July 27, 2011, 03:35:20 am » |
The Stalker v2.0 doesn't have a battery but a super capacitor for RTC backup (see here and here). I presume that the capacitor should charge immediately as soon as the board is powered up and keep the RTC ticking between resets.
« Reply #9 on: July 27, 2011, 05:09:56 pm » |
The plot thickens. The RTC behaves itself when using the RX8025 library. Here is a very stripped down version of the example source code linked in the Stalker wiki page. #include "RX8025.h" #include <Wire.h>
unsigned char hour=0; unsigned char minute=0; unsigned char second=0; unsigned char week=0; unsigned char year=0; unsigned char month=0; unsigned char date=0;
unsigned char RX8025_time[7]= { 0x00,0x54,0x09,0x03,0x10,0x11,0x10 //second, minute, hour, week, date, month, year, BCD format };
//====================================== void setup(void) { Serial.begin(9600); RX8025_init(); } //====================================== void loop(void) { getRtcTime(); print_RX8025_time(); Serial.println("--------------next--data---------------"); delay(2000); }
//============================================== void print_RX8025_time(void) { Serial.print(year,DEC); Serial.print("/"); Serial.print(month,DEC); Serial.print("/"); Serial.print(date,DEC); switch(week) { case 0x00: { Serial.print("/Sunday "); break; } case 0x01: { Serial.print("/Monday "); break; } case 0x02: { Serial.print("/Tuesday "); break; } case 0x03: { Serial.print("/Wednesday "); break; } case 0x04: { Serial.print("/Thursday "); break; } case 0x05: { Serial.print("/Friday "); break; } case 0x06: { Serial.print("/Saturday "); break; } } Serial.print(hour,DEC); Serial.print(":"); Serial.print(minute,DEC); Serial.print(":"); Serial.println(second,DEC); }
Pressing the reset button with this code loaded does not reset the RTC, unlike in the case of the DS1307RTC and Time libs, used in the "TimeRTCSet" example. Reading through the code of the RX8025 and DS1307RTC libs, I cannot for the life of me figure out what the offending difference might be. Even worse, I 'd have thought DS1307RTC shouldn't work at all since it seems to think the address of the RTC is 0x68 ( #define DS1307_CTRL_ID 0x68 in DS1307RTC.cpp below) whereas the RX8025 suggests the RTC lives at number 0x32 ( #define RX8025_address 0x32 RX8025.cpp below). DS1307RTC has what looks like a constructor whose only statement is to fire up the Wire comms: DS1307RTC::DS1307RTC() { Wire.begin(); } whereas RX8025 has function RX8025_init() which both fires up Wire comms as well as sending 0xe0 to the RTC, followed by 0x20 and 0x00. I don't know what these characters are actually doing but, for some reason, DS1307RTC seems to be communicating OK with something, even if it's at another address than whatever RX8025 is talking to and without having sent these characters. When it comes to reading time, both seem to be doing similar things. They send 0x00 and ask for some chars. However, notice a difference, in function void DS1307RTC::read( tmElements_t &tm), DS1307RTC seemingly asks for 7 values (assuming tmNbrFields == 7 as the comment suggests) whereas in function void getRtcTime(void) RX8025 asks for 8 values and discards the first one! WTF? Full code of RX8025.cpp and DS1307RTC follow. RX8025.cpp:#include <Wire.h> #include "RX8025.h" //********************************************************************
//=============================================== #define RX8025_address 0x32
unsigned char RX8025_Control[2]= { 0x20,0x00 };
//=============================================== void setRtcTime(void) { Wire.beginTransmission(RX8025_address); Wire.send(0x00); for(unsigned char i=0; i<7; i++) { Wire.send(RX8025_time); } Wire.endTransmission(); }
//=============================================== uint8_t bcd2bin (uint8_t val) { return val - 6 * (val >> 4); }
uint8_t bin2bcd (uint8_t val) { return val + 6 * (val / 10); }
//=============================================== void getRtcTime(void) { unsigned char i=0; Wire.beginTransmission(RX8025_address); Wire.send(0x00); Wire.endTransmission();// Wire.requestFrom(RX8025_address,8); RX8025_time= Wire.receive();//not use while(Wire.available()) { RX8025_time= Wire.receive(); i++; } Wire.endTransmission();//
year = bcd2bin(RX8025_time[6]&0xff); month = bcd2bin(RX8025_time[5]&0x1f); date = bcd2bin(RX8025_time[4]&0x3f); week = bcd2bin(RX8025_time[3]&0x07); hour = bcd2bin(RX8025_time[2]&0x3f); minute = bcd2bin(RX8025_time[1]&0x7f); second = bcd2bin(RX8025_time[0]&0x7f); }
//=============================================== void RX8025_init(void) { Wire.begin(); Wire.beginTransmission(RX8025_address);//clear power on reset flag, set to 24hr format Wire.send(0xe0); for(unsigned char i=0; i<2; i++) { Wire.send(RX8025_Control); } Wire.endTransmission(); //setRtcTime(); }
« Last Edit: July 27, 2011, 05:16:03 pm by ardudillo »
« Reply #10 on: July 27, 2011, 05:10:35 pm » |
DS1307RTC.cpp:/* * DS1307RTC.h - library for DS1307 RTC Copyright (c) Michael Margolis 2009 This library is intended to be uses with Arduino Time.h library functions
The library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public License along with this library; if not, write to the Free Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA 30 Dec 2009 - Initial release */
#include <Wire.h> #include "DS1307RTC.h"
DS1307RTC::DS1307RTC() { Wire.begin(); } // PUBLIC FUNCTIONS time_t DS1307RTC::get() // Aquire data from buffer and convert to time_t { tmElements_t tm; read(tm); return(makeTime(tm)); }
void DS1307RTC::set(time_t t) { tmElements_t tm; breakTime(t, tm); tm.Second |= 0x80; // stop the clock write(tm); tm.Second &= 0x7f; // start the clock write(tm); }
// Aquire data from the RTC chip in BCD format void DS1307RTC::read( tmElements_t &tm) { Wire.beginTransmission(DS1307_CTRL_ID); Wire.send(0x00); Wire.endTransmission();
// request the 7 data fields (secs, min, hr, dow, date, mth, yr) Wire.requestFrom(DS1307_CTRL_ID, tmNbrFields); tm.Second = bcd2dec(Wire.receive() & 0x7f); tm.Minute = bcd2dec(Wire.receive() ); tm.Hour = bcd2dec(Wire.receive() & 0x3f); // mask assumes 24hr clock tm.Wday = bcd2dec(Wire.receive() ); tm.Day = bcd2dec(Wire.receive() ); tm.Month = bcd2dec(Wire.receive() ); tm.Year = y2kYearToTm((bcd2dec(Wire.receive()))); }
void DS1307RTC::write(tmElements_t &tm) { Wire.beginTransmission(DS1307_CTRL_ID); Wire.send(0x00); // reset register pointer Wire.send(dec2bcd(tm.Second)) ; Wire.send(dec2bcd(tm.Minute)); Wire.send(dec2bcd(tm.Hour)); // sets 24 hour format Wire.send(dec2bcd(tm.Wday)); Wire.send(dec2bcd(tm.Day)); Wire.send(dec2bcd(tm.Month)); Wire.send(dec2bcd(tmYearToY2k(tm.Year)));
Wire.endTransmission(); } // PRIVATE FUNCTIONS
// Convert Decimal to Binary Coded Decimal (BCD) uint8_t DS1307RTC::dec2bcd(uint8_t num) { return ((num/10 * 16) + (num % 10)); }
// Convert Binary Coded Decimal (BCD) to Decimal uint8_t DS1307RTC::bcd2dec(uint8_t num) { return ((num/16 * 10) + (num % 16)); }
DS1307RTC RTC = DS1307RTC(); // create an instance for the user
« Last Edit: July 27, 2011, 05:15:03 pm by ardudillo »
« Reply #11 on: August 03, 2011, 11:24:21 pm » |
Greetings, I just have the same problems, but i have some "stupid" work-around  This is what I do, set the time in the array RX8025_time[7] i set it beyond 2 minute from the PC realtime clock. and place this in void setup() RX8025.setRtcTime(RX8025_time); After the sketch upload done, check the date/time And test is again with reset. YES the clock is ticking, but setting back to RX8025_time[7] array again. When the date/time is correct, then comment the line //RX8025.setRtcTime(RX8025_time); in the void setup() and upload the sketch again When it done, check again with reset. The clock will keep ticking and give the correct date/time after reset  I hope it helped. Sorry for the Inglish
London
Have fun!
« Reply #12 on: August 03, 2011, 11:41:45 pm » |
The Stalker 2 RTC is not compatible with the DS1307 so the RTC1307 code in the Time download wont work. Here is an updated version that autodetects the RTC type. Save the files as RTC.cpp and RTC.h. Its used in the sketch like the old library but the name is now RTC /* * RTC.cpp - library for DS1307 and RX8025 RTC chips Copyright (c) Michael Margolis 2009, 2010 This library is intended to be used with Arduino Time.h library functions
You should have received a copy of the GNU Lesser General Public License along with this library; if not, write to the Free Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA 30 Dec 2009 - Initial release for DS1307 20 Nov 2010 - renamed to RTC and Added support for DX8025 */
#include <WProgram.h> #include <Wire.h> #include "RTC.h"
//#include <HardwareSerial.h> //only needed for diagnostics
const uint8_t DS1307_ADDRESS = 0x68; const uint8_t RX8025_ADDRESS = 0x32;
const uint8_t RX8025_CTL1 = 0xE0; const uint8_t RX8025_CTL2 = 0xf0;
const uint8_t RX8025_24HR_MODE = 0x20; // set bit 5 for 24 hr mode
const uint8_t RX8025_NO_INTR = 0x0; // interupts off, INTA hi-Z const uint8_t RX8025_INTR_PER_SEC = 0x4; // INTA occurs once per second const uint8_t RX8025_INTR_PER_MIN = 0x5; // INTA occurs once per minute const uint8_t RX8025_INTR_PER_HR = 0x6; // INTA occurs once per hour const uint8_t RX8025_INTR_PER_MON = 0x7; // INTA occurs once per month
// PUBLIC FUNCTIONS
time_t RTCget() // static function that can be used as a callback { RTC.get(); }
rtcClass::rtcClass() {
} // returns true if selection is valid or autodetect succeeds in finding a device bool rtcClass::begin(RTCDevice_t selection) { device = rtcUnknown; // default to indicate that no device is selected Wire.begin(); if( selection == rtcUnknown) { // discover RTC device if(isAddressValid( RX8025_ADDRESS)) selection = rtcRX8025; else if(isAddressValid( DS1307_ADDRESS)) selection = rtcDS1307; } if(selection == rtcDS1307) { address = DS1307_ADDRESS; device = rtcDS1307; } else if(selection == rtcRX8025) { address = RX8025_ADDRESS; device = rtcRX8025; writeRegister(RX8025_CTL1,RX8025_24HR_MODE); // RX8025 defaults to 12 hr mode so change to 24hrs writeRegister(RX8025_CTL2,0); // reset power on reset flag in control register 2 } //Serial.print("device = "); Serial.println(device, DEC); //Serial.print("address = 0x"); Serial.println(address, HEX); return (device != rtcUnknown); // returns true if a valid device selected }
time_t rtcClass::get() // Aquire data from RTC and convert to time_t { tmElements_t tm; read(tm); return(makeTime(tm)); }
void rtcClass::set(time_t t) // set RTC to given time { tmElements_t tm; breakTime(t, tm); tm.Second |= 0x80; // stop the clock write(tm); tm.Second &= 0x7f; // start the clock write(tm); }
// Aquire data from the RTC chip in BCD format void rtcClass::read( tmElements_t &tm) { Wire.beginTransmission(address); Wire.send(0x00); Wire.endTransmission();
// request the data fields (secs, min, hr, dow, date, mth, yr) if( device == rtcRX8025) { Wire.requestFrom((int)address, 8); Wire.receive(); // RX8025 gets an extra byte that is ignored } else Wire.requestFrom((int)address, tmNbrFields); tm.Second = bcd2dec(Wire.receive() & 0x7f); tm.Minute = bcd2dec(Wire.receive() & 0x7f); // mask added for RX8025 tm.Hour = bcd2dec(Wire.receive() & 0x3f); // mask assumes 24hr clock tm.Wday = bcd2dec(Wire.receive() & 0x07); // mask added for RX8025 tm.Day = bcd2dec(Wire.receive() & 0x3f); // mask added for RX8025 tm.Month = bcd2dec(Wire.receive() & 0x1f); // mask added for RX8025 tm.Year = y2kYearToTm((bcd2dec(Wire.receive()))); }
void rtcClass::write(tmElements_t &tm) { Wire.beginTransmission((int)address); Wire.send(0x00); // reset register pointer Wire.send(dec2bcd(tm.Second)) ; Wire.send(dec2bcd(tm.Minute)); Wire.send(dec2bcd(tm.Hour)); // sets 24 hour format Wire.send(dec2bcd(tm.Wday)); Wire.send(dec2bcd(tm.Day)); Wire.send(dec2bcd(tm.Month)); Wire.send(dec2bcd(tmYearToY2k(tm.Year)));
// this method sets the RX8025 periodic interrupt to the given period // the INTA pin is set low at the selected interval if the interrupt is enabled void rtcClass::setPeriodicInterrupt( RTCIntrInterval_t interval) { if( device != rtcRX8025) return; // only allow this method if using RX8025 switch(interval) { case rtcIntrDisable : writeRegister(RX8025_CTL1, RX8025_24HR_MODE | RX8025_NO_INTR); break; case rtcIntrEachSecond : writeRegister(RX8025_CTL1, RX8025_24HR_MODE | RX8025_INTR_PER_SEC ); break; case rtcIntrEachMinute : writeRegister(RX8025_CTL1, RX8025_24HR_MODE | RX8025_INTR_PER_MIN ); break; case rtcIntrEachHour : writeRegister(RX8025_CTL1, RX8025_24HR_MODE | RX8025_INTR_PER_HR ); break; case rtcIntrEachMonth : writeRegister(RX8025_CTL1, RX8025_24HR_MODE | RX8025_INTR_PER_MON ); break; } }
// this method sets the INTA pin high impedence ready for next interrupt // call this after every interrupt void rtcClass::resetPeriodicInterrupt( ) { if( device == rtcRX8025) writeRegister(RX8025_CTL2, 0); // clear the control2 register }
/// returns true if there is an i2c device at the given address bool rtcClass::isAddressValid(uint8_t address) { Wire.beginTransmission(address); Wire.send(0x00); Wire.endTransmission(); Wire.requestFrom((int)address,1); delay(10); if (Wire.available() > 0 ) { Wire.receive(); //Serial.print("check for addr "); Serial.print(address,HEX), Serial.println(" returned true"); return true; } //Serial.print("check for addr "); Serial.print(address,HEX), Serial.println(" returned false"); return false; }
// sets the given register to the given value void rtcClass::writeRegister( uint8_t reg, uint8_t value) { Wire.beginTransmission((int)address); Wire.send(reg); Wire.send(value); Wire.endTransmission(); }
// Convert Decimal to Binary Coded Decimal (BCD) uint8_t rtcClass::dec2bcd(uint8_t num) { return ((num/10 * 16) + (num % 10)); }
// Convert Binary Coded Decimal (BCD) to Decimal uint8_t rtcClass::bcd2dec(uint8_t num) { return ((num/16 * 10) + (num % 16)); }
rtcClass RTC = rtcClass(); // create an instance for the user
/* * RTC.h - library for DS1307 RTC * This library is intended to be uses with Arduino Time.h library functions */
#ifndef rtcClass_h #define rtcClass_h #include <Time.h> // download from http://www.arduino.cc/playground/Code/Time
// the list of supported RTC devices enum RTCDevice_t {rtcUnknown, rtcDS1307, rtcRX8025};
// the list of interrupt intervals supported by the RX8025 enum RTCIntrInterval_t {rtcIntrDisable, rtcIntrEachSecond, rtcIntrEachMinute,rtcIntrEachHour,rtcIntrEachMonth} ; extern time_t RTCget(); // function that can be used as a sync provider callback // library interface description
class rtcClass { // user-accessible "public" interface public: rtcClass(); bool begin(RTCDevice_t device = rtcUnknown); //getExternalTime get; // pointer to the get time method time_t get(); void set(time_t t); void read(tmElements_t &tm); void write(tmElements_t &tm); void setPeriodicInterrupt( RTCIntrInterval_t interval); // RX8025 only, set the periodic interrupt void resetPeriodicInterrupt(); // call after each interrupt to reset the pin. RTCDevice_t device; // the active device private: uint8_t address; bool isAddressValid(uint8_t address); uint8_t dec2bcd(uint8_t num); uint8_t bcd2dec(uint8_t num); void writeRegister( uint8_t register, uint8_t value); };
extern rtcClass RTC;
#endif
« Reply #13 on: August 04, 2011, 10:52:40 am » |
Thank you very much mem, I was about to try adding some function to the RX8025 library that returns time_t so I could feed it to the Time library's setSyncProvider() but thankfully your library will save me from getting mauled by the compiler. I just tried your code and it initialises the RX8025 fine, as well as reading from it. However, the Time library doesn't seem to like its get() for some bizarre reason. Here is my code: #include <RTC.h> #include <Time.h> #include <Wire.h> void setup() { Serial.begin(9600); if (RTC.begin()) Serial.println("Valid RTC device initialised"); else Serial.println("Problem initialising RTC"); Serial.println("Testing the two flavours of the RTC.get() function (should return time_t):"); Serial.print(RTC.get()); Serial.print(" : "); Serial.println(RTCget()); //setSyncProvider(RTCget()); //setSyncProvider(RTC.get()); } void loop() { }
If I uncomment either line: setSyncProvider(RTCget());or setSyncProvider(RTC.get());I get the following error: error: invalid conversion from ‘time_t’ to ‘time_t (*)()’which seems strange as, if you look at the DS1307RTC library (which works fine with the Time library) the get() is declared in the DS1307RTC.h (line 17) as follows: static time_t get();So, the expected return type is time_t. No idea, how the static is breaking things. Could you please post some sample code of registering your lib's get() function as a sync provider?
London
Have fun!
« Reply #14 on: August 04, 2011, 11:50:34 am » |
sure, try this: #include <RTC.h> #include <Time.h> #include <Wire.h> void setup() { Serial.begin(9600); if (RTC.begin()) { Serial.println("Valid RTC device initialised"); setSyncProvider(RTCget); // register the get function } else { Serial.println("Problem initialising RTC"); }
} void loop() { }
