Topic: Better padding for MAX7219 (Read 63 times) previous topic - next topic
japreja
My Hardware is from here
I am using two of those 8 digit 7 segment displays with a modified LedControl library from GitHub .
When I use the Justification functions from this library, to right Justify, the display is barely readable.  But when I add the necessary padding converting a float to a string, then concatenating the converted string to a string of necessary spaces, then the speed is greatly improved.
I initially started with displaying floats, as in the examples, but reverted to converting the values to strings.
Here is my code:
/* This Code uses a modified LedControl library from https://github.com/RiveriaHorizon/LedPrint
 *  I was experiancing alot of flicker when using the Justification settings so I converted my
 *  float to strings and left padded that string with spaces which allowed for much faster speed
 *  with little to no delay
 *  I have 2
/** Printing numbers
#include <LedPrint.h>
LedPrintJustifiable myLed = LedPrintJustifiable
    11, // DATA PIN
    13, // CLOCK PIN
    10, // CS PIN
    16,  // NUMBER OF DIGITS
    1   // Orientation 0/1, if it looks backwards try the other
LedPrintJustifiable dX;
LedPrintJustifiable dY;
  // Set Brightness
  myLed.setIntensity(5);
  dY = myLed.getSubDisplay(0, 8); // First digit 0, 8 digits - first module (MAX7219)
  dX = myLed.getSubDisplay(8, 8); // First digit 8, 8 digits - second module (MAX7219)
  dX.justify(-1);
  dY.justify(-1);
  float x=0.0001;
  float y=9999.9999;
  for(float i = 0.0000; i<=9999.9999;i=i+1.001)
    String sY = String(i,4);
    String sX = String(i,4);
    if(i<10)
      sX = "   " + sX;
    else if(i>9.9999 && i<100)
      sX = "  " + sX;
    else if(i>99.9999 && i<1000)
      sX = " " + sX;
    dX.println(sX);
    dY.println(sY);
    delay(1);
  //dX.println(1234.9876,4);
  //dY.println(9876.1234,4);
  delay(250);
void printFloats(){
  // Print some floating point numbers on the right, to 2 decimal places
  myLed.justify(1);
  for(uint8_t x = 1; x < 20; x++)
    //myLed.println((float)(random(0,99999999))/((float)(random(0,9999999))),4);
    myLed.println(100.2349,4);
    delay(250);
void printDigitsJustifiedLeft(){
  // Print some numbers left justified
  myLed.justify(-1);
  for(uint8_t x = 1; x < 100; x++)
    myLed.println(x); delay(20);
void printDigitsJustifiedLeftWithPadding(){
  // Print some numbers right justified with zero pad
  myLed.justify(1, 0);
  for(uint8_t x = 1; x < 100; x+=9)
    // because of the way the justification works
    // this needs to happen a bit slower so that it doesn't
    // have too much bleed-through of the zero padding when
    // the characters are shifted in
    myLed.println(x); delay(500);
void printDigitsJustifiedRight(){
  myLed.justify(1);
void printDigitsJustifiedCenter(){
  // Print some numbers center justified
  myLed.justify(0);
I've never updated a library, or even written one, How can I replace the library's code with my padding method as it seems to work much faster?
By the way, the modified library uses the ICSP pins of the Arduino Uno.
