Loading...
Pages: 1 2 [3]   Go Down
Author Topic: Bootloader for a 1284P @ 16MHz - problems :-(  (Read 2846 times)
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
From my copy of avrdude.conf, here is how it wants to see the part id and desc names:
Quote
# ATmega1284P
# similar to ATmega164p
part
    id               = "m1284p";
    desc             = "ATMEGA1284P";
Logged
UK
Offline Offline
Sr. Member
View Profile
Quote
# ATmega1284P
part
    id               = "m1284p";
Do you have a copy of the whole section, please?
Logged
UK
Offline Offline
Sr. Member
View Profile
This is what I got changing the 664p's section with the bits I know are different (with the changes):
Code:
# ATmega1284P
part
    id               = "m1284p"; /* changed from m664p */
    desc             = "ATMEGA1284P"; /* changed from ATMEGA664P */
    has_jtag         = yes;
#   stk500_devcode   = 0x82; # no STK500v1 support
#   avr910_devcode   = 0x?;  # try the ATmega16 one:^
    avr910_devcode   = 0x74;
    signature        = 0x1e 0x97 0x05; /* changed from 0x1e 0x96 0x09 */
    pagel            = 0xd7;
    bs2              = 0xa0;
    chip_erase_delay = 9000;
    pgm_enable       = "1 0 1 0  1 1 0 0    0 1 0 1  0 0 1 1",
                       "x x x x  x x x x    x x x x  x x x x";
    chip_erase       = "1 0 1 0  1 1 0 0    1 0 0 x  x x x x",
    timeout = 200;
    stabdelay = 100;
    cmdexedelay = 25;
    synchloops = 32;
    bytedelay = 0;
    pollindex = 3;
    pollvalue = 0x53;
    predelay = 1;
    postdelay = 1;
    pollmethod = 0;
    pp_controlstack     =
        0x0E, 0x1E, 0x0F, 0x1F, 0x2E, 0x3E, 0x2F, 0x3F,
        0x4E, 0x5E, 0x4F, 0x5F, 0x6E, 0x7E, 0x6F, 0x7F,
        0x66, 0x76, 0x67, 0x77, 0x6A, 0x7A, 0x6B, 0x7B,
        0xBE, 0xFD, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02;
    hventerstabdelay    = 100;
    progmodedelay       = 0;
    latchcycles         = 6;
    togglevtg           = 0;
    poweroffdelay       = 0;
    resetdelayms        = 0;
    resetdelayus        = 0;
    hvleavestabdelay    = 15;
    chiperasepulsewidth = 0;
    chiperasepolltimeout = 10;
    programfusepulsewidth = 0;
    programfusepolltimeout = 5;
    programlockpulsewidth = 0;
    programlockpolltimeout = 5;
    idr                 = 0x31;
    spmcr               = 0x57;
    allowfullpagebitstream = no;
    memory "eeprom"
        paged           = no; /* leave this "no" */
        page_size       = 8;  /* for parallel programming */
        size            = 4096;                                       /* changed from 2048 */
        min_write_delay = 9000;
        max_write_delay = 9000;
        readback_p1     = 0xff;
        readback_p2     = 0xff;
read            = "  1   0   1   0      0   0   0   0",
                          "  0   0   x   x    a11 a10  a9  a8",
                          " a7  a6  a5  a4     a3  a2  a1  a0",
                          "  o   o   o   o      o   o   o   o";
write           = "  1   1   0   0      0   0   0   0",
                          "  i   i   i   i      i   i   i   i";
loadpage_lo = "  1   1   0   0      0   0   0   1",
 "  0   0   0   0      0   0   0   0",
 "  0   0   0   0      0  a2  a1  a0",
 "  i   i   i   i      i   i   i   i";
writepage = "  1   1   0   0      0   0   1   0",
 " a7  a6  a5  a4     a3   0   0   0",
 "  x   x   x   x      x   x   x   x";
mode = 0x41;
delay = 10;
blocksize = 128;
readsize = 256;
    memory "flash"
        paged           = yes;
        size            = 131072; /* changed from 65536 */
        page_size       = 256;
        num_pages       = 512;                                  /* changed from 256 */
        min_write_delay = 4500;
        max_write_delay = 4500;
        readback_p1     = 0xff;
        readback_p2     = 0xff;
        read_lo         = "  0   0   1   0      0   0   0   0",
                          "a15 a14 a13 a12    a11 a10  a9  a8",
                          "  o   o   o   o      o   o   o   o";
        read_hi         = "  0   0   1   0      1   0   0   0",
                          "  o   o   o   o      o   o   o   o";
        loadpage_lo     = "  0   1   0   0      0   0   0   0",
                          "  0   0   x   x      x   x   x   x",
                          "  x  a6  a5  a4     a3  a2  a1  a0",
                          "  i   i   i   i      i   i   i   i";
        loadpage_hi     = "  0   1   0   0      1   0   0   0",
                          "  0   0   x   x      x   x   x   x",
                          "  i   i   i   i      i   i   i   i";
        writepage       = "  0   1   0   0      1   1   0   0",
                          " a7   x   x   x      x   x   x   x",
                          "  x   x   x   x      x   x   x   x";
mode = 0x21;
delay = 6;
blocksize = 256;
readsize = 256;
    memory "lock"
        size            = 1;
        read            = "0 1 0 1  1 0 0 0   0 0 0 0  0 0 0 0",
                          "x x x x  x x x x   x x o o  o o o o";
        write           = "1 0 1 0  1 1 0 0   1 1 1 x  x x x x",
                          "x x x x  x x x x   1 1 i i  i i i i";
    memory "lfuse"
        size            = 1;
        read            = "0 1 0 1  0 0 0 0   0 0 0 0  0 0 0 0",
                          "x x x x  x x x x   o o o o  o o o o";
        write           = "1 0 1 0  1 1 0 0   1 0 1 0  0 0 0 0",
                          "x x x x  x x x x   i i i i  i i i i";
    memory "hfuse"
        size            = 1;
        read            = "0 1 0 1  1 0 0 0   0 0 0 0  1 0 0 0",
        write           = "1 0 1 0  1 1 0 0   1 0 1 0  1 0 0 0",
    memory "efuse"
        size            = 1;
        read            = "0 1 0 1  0 0 0 0  0 0 0 0  1 0 0 0",
        write           = "1 0 1 0  1 1 0 0  1 0 1 0  0 1 0 0",
                          "x x x x  x x x x  1 1 1 1  1 i i i";
    memory "signature"
        size            = 3;
        read            = "0  0  1  1   0  0  0  0   x  x  x  x   x  x  x  x",
                          "x  x  x  x   x  x a1 a0   o  o  o  o   o  o  o  o";
    memory "calibration"
        size            = 1;
        read            = "0 0 1 1  1 0 0 0   0 0 0 x  x x x x",
                          "0 0 0 0  0 0 0 0   o o o o  o o o o";
« Last Edit: June 21, 2011, 11:34:20 am by cowasaki » Logged
Offline Offline
Brattain Member
View Profile
Quote
Quote
# ATmega1284P
part
    id               = "m1284p";
    has_jtag         = yes;
    stk500_devcode   = 0x82; # no STK500v1 support, use the ATmega16 one
    pagel            = 0xd7;
    bs2              = 0xa0;
    timeout      = 200;
    stabdelay      = 100;
    cmdexedelay      = 25;
    synchloops      = 32;
    bytedelay      = 0;
    pollindex      = 3;
    pollvalue      = 0x53;
    predelay      = 1;
    postdelay      = 1;
    pollmethod      = 1;
    pp_controlstack     =
    progmodedelay       = 0;
    latchcycles         = 6;
    togglevtg           = 1;
    poweroffdelay       = 15;
    resetdelayms        = 1;
    resetdelayus        = 0;
    idr                 = 0x31;
    spmcr               = 0x57;
    memory "eeprom"
        size            = 4096;
        readback_p1     = 0xff;
        readback_p2     = 0xff;
                          "  o   o   o   o      o   o   o   o";
                          "  i   i   i   i      i   i   i   i";
           "  0   0   0   0      0   0   0   0",
           "  i   i   i   i      i   i   i   i";
           "  x   x   x   x      x   x   x   x";
   mode      = 0x41;
   delay      = 10;
   blocksize   = 128;
   readsize   = 256;
    memory "flash"
        paged           = yes;
        size            = 131072;
        page_size       = 256;
        num_pages       = 512;
        readback_p1     = 0xff;
        readback_p2     = 0xff;
                          "  o   o   o   o      o   o   o   o";
                          "  o   o   o   o      o   o   o   o";
                          "  0   0   x   x      x   x   x   x",
                          "  i   i   i   i      i   i   i   i";
                          "  0   0   x   x      x   x   x   x",
                          "  i   i   i   i      i   i   i   i";
                          "  x   x   x   x      x   x   x   x";
   mode      = 0x41;
   delay      = 10;
   blocksize   = 256;
   readsize   = 256;
    memory "lock"
        size            = 1;
    memory "lfuse"
        size            = 1;
    memory "hfuse"
        size            = 1;
    memory "efuse"
        size            = 1;
    memory "signature"
        size            = 3;
        size            = 1;
Logged
UK
Offline Offline
Sr. Member
View Profile
WOW - IT WORKS !!!!!!
With the above changes the Arduino will upload a sketch to the 1284p and it works.  My 1284p is now blinking away happily.........
Right now I need to do a detailed list of everything that needs to be done and will post it (with reference to the fabulous help I have received from everyone!)
I have not tested it beyond the blink sketch but getting that working was very helpful.
Logged
UK
Offline Offline
Sr. Member
View Profile
Quote
Quote
# ATmega1284P
Thanks RetroLefty, that matches the one I just worked out so happy with that.
Logged
Pages: 1 2 [3]   Go Up
Print
Jump to:
